Hello!
I have recently integrated my smart kettle with Openhab (via Bluetooth), and of course decided to add it to Alexa in order to control it by voice.
First of all, I didn’t find a kettle in the capabilities list (despite Alexa has “Kettle” in its’ smart devices), so I have used “WaterHeater” instead.
Second, here’s how I have configured it in Openhab:
See - temperature is always frozen at “-50 C”. The rest of functionality works - switching the device on/off and setting target temperature.
So, how can I fix the current temperature in Alexa?
Try to delete and rediscover your device on the Alexa side.
If that doesn’t work, can you please provide the OH version you are running and the JSON output of your Kettle_CurrentTemperature item using the Developer Tools > API Explorer?
Thanks for the information. I was able to replicate your issue. Basically, the state for a given Number with a dimension which doesn’t have a defined state presentation was not reported back to Alexa. This is why you weren’t seeing the proper state on the Alexa side.
Prior to OH 4.0, I believe a default state presentation was always defined preventing this issue from occurring. Anyway, I have pushed a change to fix this issue and should be released to the live skill in the next few days.
In the meantime, the workaround would be to set your item state presentation.
