marvo88
(Martin)
February 26, 2025, 1:06pm
1
I had a habpanel with my wishes that worked, meanwhile I want to change to mainUI, but I dont able to create widgets with my wishes.
Now I try to create a Heating Overview, but I didnt successful.
I attached a picture with my status and my wish and my latest code.
I hope someone can help me…
uid: Heizung
tags: []
props:
parameters:
- description: Title
label: Title
required: false
type: TEXT
- context: item
description: Temperature sensor at top
label: Temp Top
required: false
type: TEXT
parameterGroups: []
timestamp: Feb 26, 2025, 1:46:11 PM
component: f7-card
class:
- padding
style:
background-color: "=props.bgcolor ? props.bgcolor : ''"
box-shadow: 5px 5px 10px 1px rgba(0,0,0,0.1)
height: 120px
margin-left: 5px
margin-right: 5px
noShadow: false
padding: 0px
slots:
default:
- component: f7-block
style:
min-height: 180px
max-height: 180px
max-width: 120px
min-width: 120px
background: url(/static/boiler.png)
background-size: cover
background-position: right bottom
display: flex
flex-direction: column
align-items: start
slots:
default:
- component: f7-row
class:
- display-flex
- justify-content-space-between
- align-content-stretch
- align-items-center
slots:
default:
- component: f7-col
class:
- display-flex
- flex-direction-column
slots:
default:
- component: Label
text: Puffer
style:
font-size: 12px
- component: f7-icon
f7: rectangle_fill
color: '=(items[props.item_top].state.split(".")[0] < 46) ? "blue" : ((items[props.item_top].state.split(".")[0] < 60) ? "orange" : "red")'
style:
top: 2px
left: 10px
transform: rotate(90deg)
filter: opacity(40%)
- component: oh-link
text: =items[props.item_top].state + " °C"
action: analyzer
actionAnalyzerItems: =[props.item_top]
style:
top: 2px
font-size: 14px
font-weight: bold
- component: f7-col
class:
- display-flex
slots:
default:
- component: Label
text: "Vorlauf :"
style:
font-size: 12px
stue
(Matthias)
February 26, 2025, 8:37pm
2
uid: wid_Test_boiler
tags: []
props:
parameters:
- context: item
default: Test_GroupOne_NumberItem
description: item for Vorlauf
label: Item
required: false
type: TEXT
- context: item
description: item for Leistung
label: Item
required: false
type: TEXT
- default: /static/boiler.png
description: /static/myImage.jpg
label: Background image-url
required: false
type: TEXT
parameterGroups: []
timestamp: Feb 26, 2025, 8:22:46 PM
component: f7-card
class:
#- padding
style:
height: 120px
margin-left: 5px
margin-right: 5px
noShadow: false
display: flex
#padding: 0px
slots:
default:
- component: div
style:
background-image: "='url(' + props.backgroundUrl + ')'"
#display: flex
flex-grow: 1
clip-path: ="inset( 0px round var(--f7-card-expandable-border-radius))"
#min-height: 180px
##max-height: 180px
#max-width: 120px
#min-width: 120px
#background-size: cover
#background-position: right bottom
#display: flex
#flex-direction: column
#align-items: start
#- component: f7-card-content
# config:
# style:
# display: flex
# #background: lightgreen
slots:
default:
- component: f7-row
class:
#- display-flex
#- justify-content-space-between
#- align-content-stretch
#- align-items-center
style:
#display: flex
background: yellow)
filter: opacity(60%)
align-items: stretch
#flex-grow: 1
#border-radius: var(--f7-card-expandable-border-radius)
border-radius: 50px
slots:
default:
- component: f7-col
class:
- display-flex
#- flex-direction-column
- justify-content-center
style:
background: lightgrey
slots:
default:
- component: f7-col
class:
- display-flex
style:
slots:
default:
- component: Label
text: Puffer
style:
font-size: 12px
f7: rectangle_fill
color: "=(items[props.item_top].state.split('.')[0] < 46) ? 'blue' : ((items[props.item_top].state.split('.')[0] < 60) ? 'orange' : 'red')"
style:
#top: 2px
#left: 10px
- component: f7-col
class:
- display-flex
style:
slots:
default:
text: =items[props.item_top].state + ' °C'
action: analyzer
style:
#top: 2px
#font-size: 14px
font-weight: bold
background: purple
- component: f7-col
class:
- display-flex
style:
slots:
default:
- component: Label
text: "='Vorlauf: ' + items[props.itmVorlauf].state + ' °C'"
style:
font-size: 12px
- component: Label
text: "='Leistung: ' + items[props.itmLeistung].state + ' W'"
style:
font-size: 12px
- component: f7-col
class:
- display-flex
style:
background: lightblue
slots:
default:
- component: oh-button
class:
- display-flex
style:
flex-grow: 1
slots:
default:
- component: Label
text: 'Heizung: '
style:
font-size: 12px
- component: Label
text: 'ON'
style:
font-size: 12px
Hopefully you can pick up a few useful things.
I believe you, like I did, had trouble understanding CSS Flexbox. I use for every second widget I work on: CSS3 Flexbox because I just can’t keep it all in my head.
I added some background colors to clarify where each container is located. I also left your code so that you can compare and reassign it.
Of course, this is just a code suggestion and it needs to be cleaned up.
marvo88
(Martin)
February 27, 2025, 8:35am
3
Hi Matthias,
thank you very much for your help.
I was able to configure my widget with two open questions:
My switch has no changing color to red and no hand over it like the oh-button
How I can add the background picture of the water-buffer for the rectangle in your example?
uid: Heizung
tags: []
props:
parameters:
- context: item
description: item for Puffer Top
label: Item
required: false
type: TEXT
- context: item
label: Item
required: false
type: TEXT
- context: item
label: Item
required: false
type: TEXT
- context: item
description: item for Heizung
label: Item
required: false
type: TEXT
required: false
type: TEXT
parameterGroups: []
component: f7-card
class:
#- padding
style:
height: 120px
margin-left: 5px
margin-right: 5px
noShadow: false
display: flex
#padding: 0px
slots:
default:
- component: div
style:
#display: flex
flex-grow: 1
#min-height: 180px
##max-height: 180px
#max-width: 120px
#min-width: 120px
#display: flex
#align-items: start
# config:
# style:
# display: flex
slots:
default:
- component: f7-row
class:
#- display-flex
style:
#display: flex
#background: yellow)
#filter: opacity(60%)
#flex-grow: 1
border-radius: 50px
slots:
default:
- component: f7-col
class:
- display-flex
style:
# background: lightgrey
# filter: opacity(60%)
slots:
default:
- component: f7-col
class:
- display-flex
style:
#background: lightgrey
slots:
default:
- component: Label
text: Puffer
style:
font-size: 12px
f7: rectangle_fill
style:
#top: 2px
#left: 10px
- component: f7-col
class:
- display-flex
style:
slots:
default:
action: analyzer
style:
#top: 2px
font-size: 20px
font-weight: bold
#background: purple
- component: f7-col
class:
- display-flex
- align-items-left
# style:
# background: lightgreen
slots:
default:
- component: Label
style:
font-size: 12px
- component: Label
style:
font-size: 12px
- component: f7-col
class:
- display-flex
style:
#background: lightblue
slots:
default:
- component: Label
text: 'Heizung: '
style:
font-size: 12px
- component: oh-icon
icon: switch
action: toggle
actionItem: =props.itmHeizung
actionCommand: OFF
actionCommandAlt: ON
height: 50
style:
color: =(@props.itmHeizung == "ON") ? "green":"red"
- component: Label
text: =(@props.itmHeizung == "ON") ? "ON":"OFF"
style:
font-size: 12px
JustinG
(JustinG)
February 27, 2025, 3:16pm
4
By just using icon: switch, you have selected one of the OH icons. These icons cannot be re-colored directly (there was some recent work on this, but I don’t think it is complete yet). There are a couple of different solutions: 1) find a similar or preferable icon from one of the other icon providers such as f7:power because these icon can be recolored or 2) use the state-base variants of the OH icon you want, in this case switch-on and switch-off. In case #2 you would not need the color directive in the style object at all, you would move the expression up to the actual icon property itself:
icon: =(@props.itmHeizung == "ON") ? "switch-on":"switch-off"
The oh-button becomes and html <a> tag when it is rendered on the page, which usually automatically get the pointer cursor when hovered over. The oh-icon, on the other hand gets rendered as an <img> tag. So, if you want the cursor to change when over the icon you have to do that manually with the css style:
style:
cursor: pointer
You’ll have to do that with css too. The image needs to be some place OH can access it (usually this means placing it in the html folder in your OH conf folder). Then the url to access the image will be /static/image.name.
W3Schools offers free online tutorials, references and exercises in all the major languages of the web. Covering popular subjects like HTML, CSS, JavaScript, Python, SQL, Java, and many, many more.
stue
(Matthias)
February 27, 2025, 7:11pm
5
I already did the css job by:
style:
You only need to drop your image into /etc/openhab/html/ and either…
…adjust the default settings in the widget code.
- default: /static/boiler.png #<---- just change "boiler.png" to ...
description: /static/boiler.png
required: false
type: TEXT
… or change individual widget-settings (set props)
marvo88
(Martin)
February 27, 2025, 7:49pm
6
thank you very much, I got the switch icon and the hand-cursor, thanks.
But, if I set the picture, I have the picture in each column. I would like have the picture only behind the rectangle_fill like in the attached picture.
stue
(Matthias)
February 27, 2025, 8:25pm
7
replace…:
- component: Label
text: Puffer
style:
font-size: 12px
f7: rectangle_fill
style:
#top: 2px
#left: 10px
…with:
- component: Label
text: Puffer
style:
font-size: 12px
- component: oh-image
url: =props.backgroundUrl
style:
margin: 0.3cqh
height: 8cqh
width: 5cqh
and delete the background-image from top container:
- component: div
style:
#background-image: "='url(' + props.backgroundUrl + ')'" <--- delete
for your round corners play with:
border-radius
stue
(Matthias)
February 27, 2025, 9:38pm
8
uid: wid_boiler
tags: []
props:
parameters:
- context: item
description: item with the Vorlauf temperature
label: Item
required: false
type: TEXT
- context: item
description: item with the power
label: Item
required: false
type: TEXT
- context: item
description: item with the fill-level
label: Item
required: false
type: TEXT
- default: /static/bild.png
description: (url(/static/boiler.png))
required: false
type: TEXT
parameterGroups: []
timestamp: Feb 27, 2025, 9:08:58 PM
component: f7-card
style:
height: 120px
margin-left: 5px
margin-right: 5px
noShadow: false
display: flex
slots:
default:
- component: div
style:
flex-grow: 1
slots:
default:
- component: f7-row
style:
slots:
default:
- component: f7-col
class:
- display-flex
style:
background: none
filter: none
slots:
default:
- component: f7-col
class:
- display-flex
style:
background: none
filter: none
slots:
default:
- component: Label
text: Puffer
style:
font-size: 12px
#______________________________________________________________________________________
#Maybe you'd like to visualize the level based on the state of an item declared in props.
- component: div
style:
margin: 0.3cqh
height: 8cqh
position: relative
slots:
default:
style:
height: 100%
- component: div
style:
position: absolute
top: "=(100 - items[props.itmLevel].state) + '%'"
bottom: 0
left: 0
right: 0
background: red
- component: f7-col
class:
- display-flex
style:
background: none
filter: none
slots:
default:
action: analyzer
style:
font-weight: bold
background: none
- component: f7-col
class:
- display-flex
style:
background: none
filter: none
slots:
default:
- component: Label
style:
font-size: 12px
- component: Label
style:
font-size: 12px
- component: f7-col
class:
- display-flex
style:
background: none
filter: none
slots:
default:
class:
- display-flex
style:
flex-grow: 1
slots:
default:
- component: Label
text: "Heizung: "
style:
font-size: 12px
- component: Label
text: ON
style:
font-size: 12px
marvo88
(Martin)
March 6, 2025, 7:45am
9
Thank you very much,
I use it without the level, only a rectangle_fillwith a changing color.
The widget works, but I think I will seperate the button, because on my tablet it is not all in the box.
Thanks.
