I feel like this thing just won’t die. First off I had to change the name from weather1, cfg to weather.cfg to get anything from the logs. I feel as though I’ve read every post from every weather binding on this site. Any idea why Nest is mentioned?
weather:apikey.ForecastIo=
e500feb463b2a9803308a9c6******
weather:location.home.name=
home
weather:location.home.latitude=41.****
weather:location.home.longitude=-71.****
weather:location.home.woeid= (required for Yahoo provider)
weather:location.home.provider=ForecastIo
weather:location.home.language=
EN
weather:location.home.updateInterval=
60
Updating property apikey.ForecastIo of configuration org.openhab.nest caused a problem: the given configKey ‘apikey.ForecastIo’ is unknown
2017-02-07 19:26:58.652 [WARN ] [eather.internal.common.WeatherConfig] - Weather apikey setting ‘apikey.ForecastIo’ has no value. Check openhab.cfg.
2017-02-07 19:26:58.652 [WARN ] [eather.internal.common.WeatherConfig] - Weather apikey setting ‘apikey.Wunderground’ has no value. Check openhab.cfg.
2017-02-07 19:26:58.652 [WARN ] [eather.internal.common.WeatherConfig] - Weather location setting ‘location.home.language’ has no value. Check openhab.cfg.
2017-02-07 19:26:58.653 [WARN ] [eather.internal.common.WeatherConfig] - Weather location setting ‘location.home.name’ has no value. Check openhab.cfg.
2017-02-07 19:26:58.653 [WARN ] [eather.internal.common.WeatherConfig] - Weather location setting ‘location.home.updateInterval’ has no value.
