I’m using the weather binding with oh2 and Wonderground.
Actual Dates works fine.
Even if I tried to define an item with forecast like
Number Unna_TempMinMorgen “erwartete Temperatur (min) [%.1f °C]” {weather=“locationId=Unna, forecast=1, type=temperature, property=min”}
I don’t get any fvalues.
If I used the itemwithout “forecast=1” the item works and gives min-temperature of the current day . “forecast=0” doesn’t work either.
Did someone know why?
For information:I have a wonderground api-key for free and select the option “Anvil Plan”.
yes. After starting OH again, the openhab.log shows a log of warnings (homematic-items are not found and a warning that my sitemap does not match the name demo of the sitemap).
In events.log I only can see the status-changes of items (even weather-items), but not of the item with forecast.
Number WeatherForecast1MinTemp "Tomorrow min Temp [%.1f °C]" (Weather) { weather="locationId=home, forecast=1, type=temperature, property=min" }
Copy the binding part and replace it into yours.
Notice that there is a space after the { and before the }, for some reason the binding parser like these and I have had problems without the spaces despite the examples in the the docs.
If that doesn’t work, uninstall the binding retart OH and re-install the binding, it can unblock things too.
