Hi, I’m getting this error frequently in openhab.log:
2020-03-13 20:31:46.463 [INFO ] [control.internal.WebSocketConnection] - Web Socket error
java.nio.channels.AsynchronousCloseException: null
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.close(HttpConnectionOverHTTP.java:181) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1257) [?:1.8.0_152]
at org.eclipse.jetty.client.AbstractConnectionPool.close(AbstractConnectionPool.java:208) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.DuplexConnectionPool.close(DuplexConnectionPool.java:237) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpDestination.close(HttpDestination.java:385) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpClient.doStop(HttpClient.java:260) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:93) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.stop(ContainerLifeCycle.java:180) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStop(ContainerLifeCycle.java:201) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.client.WebSocketClient.doStop(WebSocketClient.java:371) [bundleFile:9.4.20.v20190813]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection.close(WebSocketConnection.java:159) [bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection$2.run(WebSocketConnection.java:184) [bundleFile:?]
at java.util.TimerThread.mainLoop(Timer.java:555) [?:1.8.0_152]
at java.util.TimerThread.run(Timer.java:505) [?:1.8.0_152]
Any idea, what causes this?
(I haven’t seen this until one hour ago…)
I´m getting the same errors after upgrading to openHAB 2.5.2 but still using the 2.5.0.-2019-10-23 Amazon Echo Control Binding.
2020-03-13 23:34:46.434 [INFO ] [control.internal.WebSocketConnection] - Web Socket error {}
at java.util.ArrayList.forEach(ArrayList.java:1257) [?:1.8.0_222]
at java.util.TimerThread.mainLoop(Timer.java:555) [?:1.8.0_222]
at java.util.TimerThread.run(Timer.java:505) [?:1.8.0_222]
And also some none Amazon WebSocket errors
2020-03-13 23:37:54.621 [INFO ] [control.internal.WebSocketConnection] - Web Socket error {}
org.eclipse.jetty.io.EofException: null
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:283) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.flush(SslConnection.java:910) ~[bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:422) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:277) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:381) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.io.FrameFlusher.flush(FrameFlusher.java:264) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.io.FrameFlusher.process(FrameFlusher.java:193) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:223) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.outgoingFrame(AbstractWebSocketConnection.java:516) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.client.io.WebSocketClientConnection.outgoingFrame(WebSocketClientConnection.java:72) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.close(AbstractWebSocketConnection.java:184) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:458) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:428) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:426) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:320) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:158) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Caused by: java.io.IOException: Datenübergabe unterbrochen (broken pipe)
at sun.nio.ch.FileDispatcherImpl.write0(Native Method) ~[?:1.8.0_222]
at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47) ~[?:1.8.0_222]
at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93) ~[?:1.8.0_222]
at sun.nio.ch.IOUtil.write(IOUtil.java:51) ~[?:1.8.0_222]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:471) ~[?:1.8.0_222]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:261) ~[bundleFile:9.4.20.v20190813]
... 23 more
I had the same issue last evening and ended up I uninstalled the amazon binding till this morning as it appears it must have a memory leak when the connection is broken, I’m using a pi 3B+ and generally the service runs with between 18 and 20% free ram last night I started to get alerts, based on rules, that free ram had dropped to less than 10% and was still falling which is when I uninstalled the binding.
Reinstalled this morning and everything is back to normal so far, as previously mentioned this looks like it may have been an issue on the Amazon side given a few of us had the errors, mine started 18:30 GMT but no idea when it was resolved given the dropping of the binding.
K
Had a look at my logs and the issue is gone.
Seems like a problem at the Amazon end.
Anyway, @michi should look into it and maybe handle it better in the binding.
