Web Socket error - javax.net.ssl.SSLHandshakeException: Abruptly closed by peer
Platform information:
  • openHAB Hardware: Raspi 3 B+ (Raspian OS 10)
  • openHAB Software: 3.1.0 Release Build, running on Docker / Portainer 2.9.2
  • openHAB Bindings: Homematic Binding (logging the heating, controlling lights and blinds), Gardena Binding for Gardena Gateway / smart irrigation control (logging soil humidity), Alexa Binding (controlling the Homematic lights)
  • Homematic IP Hardware: CCU2 (2.59.7), multiple Homematic IP devices
  • Other Hardware: Amber Wireless AMB8465 stick to read out Wireless M-Bus from water & heat meter
I’m having one annoying problem around a two odd log entries. Not sure if they’re connected, so here we go:
Annoying problem: Alexa loses connection from time to time
  • The Alexa binding appears to lose connection from time to time (“Device unresponsive” in the Alexa App)…
  • … with no related entries in the log…
  • … but, even though Alexa cannot reach the devices, I can e.g. still make Alexa speak (e.g. via a simple command events.sendCommand(“Echo_Dot_Speak”, “Test”);), so the connection is somehow still there? Alexa just can’t control devices.
  • This problem can also be solved via a reboot of openHAB (either in Portainer or the entire Raspi).
  • Whenever Alexa has lost connection, https://myopenhab.org/ also correctly reports “Your openHAB is offline.”
So far so good.
Here’s what I also have in the logs. As said, I have these entries independent from “everything working normal” (e.g. after a reboot) as well as “when Alexa has lost connection”, so they show up anyway, even if everything works normal
1) Web Socket close 1005. Reason: null
2021-11-16 20:53:11.160 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-16 20:54:27.596 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-16 20:55:39.428 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-16 20:56:44.938 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-16 20:58:01.821 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-16 20:59:11.622 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-16 21:00:21.772 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-16 21:01:31.646 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-16 21:02:41.468 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-16 21:03:54.010 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-16 21:05:03.882 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-16 21:06:20.383 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-11-16 21:07:36.630 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
This is what I understood is also being reported here, so I assume this can be ignored?!? Or is there a connection to the problem described above?
2) Web Socket error - javax.net.ssl.SSLHandshakeException: Abruptly closed by peer
Every now and then this is in my log:
20:51:54.601 [INFO ] [ocontrol.internal.WebSocketConnection] - Web Socket error
	at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:752) ~[?:?]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:164) ~[?:?]
	at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:79) ~[?:?]
	at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[?:?]
	at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:169) ~[?:?]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[?:?]
	at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:540) ~[?:?]
	at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:395) ~[?:?]
	at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:161) ~[?:?]
	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[?:?]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:882) [bundleFile:9.4.40.v20210413]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1036) [bundleFile:9.4.40.v20210413]
	Suppressed: javax.net.ssl.SSLException: closing inbound before receiving peer's close_notify
		at sun.security.ssl.Alert.createSSLException(Alert.java:133) ~[?:?]
		at sun.security.ssl.Alert.createSSLException(Alert.java:117) ~[?:?]
		at sun.security.ssl.TransportContext.fatal(TransportContext.java:336) ~[?:?]
		at sun.security.ssl.TransportContext.fatal(TransportContext.java:292) ~[?:?]
		at sun.security.ssl.TransportContext.fatal(TransportContext.java:283) ~[?:?]
		at sun.security.ssl.SSLEngineImpl.closeInbound(SSLEngineImpl.java:733) ~[?:?]
		at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.closeInbound(SslConnection.java:965) ~[?:?]
		at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:749) ~[?:?]
	Suppressed: org.eclipse.jetty.io.EofException
		at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:279) ~[?:?]
		at org.eclipse.jetty.io.ssl.SslConnection.networkFlush(SslConnection.java:474) ~[?:?]
		at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.flush(SslConnection.java:1080) ~[?:?]
		at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.doShutdownOutput(SslConnection.java:1292) ~[?:?]
		at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.doClose(SslConnection.java:1374) ~[?:?]
		at org.eclipse.jetty.io.AbstractEndPoint.doOnClose(AbstractEndPoint.java:220) ~[?:?]
		at org.eclipse.jetty.io.AbstractEndPoint.close(AbstractEndPoint.java:192) ~[?:?]
		at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.fill(SslConnection.java:828) ~[?:?]
	Caused by: java.io.IOException: Broken pipe
		at sun.nio.ch.FileDispatcherImpl.writev0(Native Method) ~[?:?]
		at sun.nio.ch.SocketDispatcher.writev(SocketDispatcher.java:51) ~[?:?]
		at sun.nio.ch.IOUtil.write(IOUtil.java:182) ~[?:?]
		at sun.nio.ch.IOUtil.write(IOUtil.java:130) ~[?:?]
		at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:493) ~[?:?]
		at java.nio.channels.SocketChannel.write(SocketChannel.java:507) ~[?:?]
		at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:273) ~[?:?]
		... 21 more
3) Raspi OS Log full of odd messages:
Nov 16 20:50:01 hab kernel: [   24.879570] eth0: renamed from vethb9fc507
Nov 16 20:50:01 hab kernel: [   24.927144] docker0: port 1(vetha7baf56) entered blocking state
Nov 16 20:50:01 hab kernel: [   24.927168] docker0: port 1(vetha7baf56) entered forwarding state
Nov 16 20:50:01 hab kernel: [   25.348713] eth0: renamed from veth25cd52f
Nov 16 20:50:01 hab kernel: [   25.401024] app-openhab3: port 1(veth7855514) entered blocking state
Nov 16 20:50:01 hab kernel: [   25.401049] app-openhab3: port 1(veth7855514) entered forwarding state
Nov 16 20:50:02 hab kernel: [   25.676261] eth0: renamed from vethd995a4a
Nov 16 20:50:02 hab kernel: [   25.714777] eth0: renamed from vethe3376ad
Nov 16 20:50:02 hab kernel: [   25.757971] br-90c87d73d85f: port 1(veth08729ea) entered blocking state
Nov 16 20:50:02 hab kernel: [   25.757993] br-90c87d73d85f: port 1(veth08729ea) entered forwarding state
Nov 16 20:50:02 hab kernel: [   25.759338] br-0e8cc1951b33: port 1(vethdb1a6a5) entered blocking state
Nov 16 20:50:02 hab kernel: [   25.759378] br-0e8cc1951b33: port 1(vethdb1a6a5) entered forwarding state
Nov 16 20:50:02 hab kernel: [   26.045400] eth0: renamed from veth5ca4745
Nov 16 20:50:02 hab kernel: [   26.104900] eth0: renamed from vethf4218cc
Nov 16 20:50:02 hab kernel: [   26.236912] eth0: renamed from veth8197d1f
Nov 16 20:50:02 hab kernel: [   26.285393] be-openhab3: port 1(veth932fc1c) entered blocking state
Nov 16 20:50:02 hab kernel: [   26.285409] be-openhab3: port 1(veth932fc1c) entered forwarding state
Nov 16 20:50:02 hab kernel: [   26.285636] eth0: renamed from vethed4f765
Nov 16 20:50:02 hab kernel: [   26.355894] app-openhab3: port 2(veth9a50b47) entered blocking state
Nov 16 20:50:02 hab kernel: [   26.355909] app-openhab3: port 2(veth9a50b47) entered forwarding state
Nov 16 20:50:02 hab kernel: [   26.356383] app-openhab3: port 3(veth7244a50) entered blocking state
Nov 16 20:50:02 hab kernel: [   26.356394] app-openhab3: port 3(veth7244a50) entered forwarding state
Nov 16 20:50:02 hab kernel: [   26.358079] app-openhab3: port 4(veth97ad3d1) entered blocking state
Nov 16 20:50:02 hab kernel: [   26.358109] app-openhab3: port 4(veth97ad3d1) entered forwarding state
Nov 16 20:50:02 hab kernel: [   26.545142] eth1: renamed from veth3c8d90d
Nov 16 20:50:02 hab kernel: [   26.595610] eth1: renamed from veth14171cf
Nov 16 20:50:03 hab kernel: [   26.726980] be-openhab3: port 3(veth5aee02b) entered blocking state
Nov 16 20:50:03 hab kernel: [   26.726997] be-openhab3: port 3(veth5aee02b) entered forwarding state
Anyone having an idea?
Update: After having had a bunch of connectivity problems for months, and after (unsuccessfully) having changed almost everything except the rounter, I finally replaced the router with something decent (Fritz! Box). And voillà: All my connectivity problems were gone.
The error javax.net.ssl.SSLHandshakeException: Abruptly closed by peer usually points to a TLS version mismatch or an untrusted/invalid SSL certificate. Ensure both client and server are configured to use compatible TLS versions (like TLS 1.2 or 1.3), and verify that the server’s certificate is valid and trusted by the client.
