Hi everyone.
I need the help of the team!
I can not figure out where the error I get from the OpenHab log comes from. I use the 2.4 Stable.
2019-01-23 15:34:51.991 [INFO ] [control.internal.WebSocketConnection] - Web Socket error {}
org.eclipse.jetty.io.EofException: null
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:286) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.flush(SslConnection.java:1005) ~[75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:429) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:323) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:380) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.FrameFlusher.flush(FrameFlusher.java:218) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.FrameFlusher.process(FrameFlusher.java:157) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.FrameFlusher.enqueue(FrameFlusher.java:90) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.outgoingFrame(AbstractWebSocketConnection.java:495) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.client.io.WebSocketClientConnection.outgoingFrame(WebSocketClientConnection.java:72) [91:org.eclipse.jetty.websocket.client:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.WebSocketSession.close(WebSocketSession.java:223) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.WebSocketSession.close(WebSocketSession.java:202) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onConnectionStateChange(AbstractWebSocketConnection.java:353) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.IOState.notifyStateListeners(IOState.java:184) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.IOState.onReadFailure(IOState.java:498) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.readParse(AbstractWebSocketConnection.java:547) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:391) [92:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:291) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ssl.SslConnection$3.succeeded(SslConnection.java:151) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at java.lang.Thread.run(Unknown Source) [?:?]
Caused by: java.io.IOException: Connessione in corso interrotta forzatamente dall'host remoto
at sun.nio.ch.SocketDispatcher.write0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.write(Unknown Source) ~[?:?]
at sun.nio.ch.IOUtil.writeFromNativeBuffer(Unknown Source) ~[?:?]
at sun.nio.ch.IOUtil.write(Unknown Source) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(Unknown Source) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:264) ~[?:?]
... 27 more
2019-01-23 15:34:52.017 [INFO ]
[control.internal.WebSocketConnection] - Web Socket close 1006. Reason: WebSocket Read EOF
No idea of what the origin of the error may be?
This is the whole LOG
... 27 more
2019-01-25 09:01:06.846 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1006. Reason: WebSocket Read EOF
Thanks for the reply.
Yes, I am using it continuously and it runs smoothly regularly.
The configuration is the basic one with UUID and Secret without “Item to Expose”. Where can the problem be?
I already have the connector installed. I removed it and then reconfigured it. I still have the same mistake and would like to solve it. In my opinion the error I notice has nothing to do with the cloud connection. Who helps me?
2020-06-14 18:50:52.420 [INFO ] [control.internal.WebSocketConnection] - Web Socket error
java.nio.channels.AsynchronousCloseException: null
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.close(HttpConnectionOverHTTP.java:181) ~[?:?]
at java.util.ArrayList.forEach(ArrayList.java:1257) [?:1.8.0_152]
at org.eclipse.jetty.client.AbstractConnectionPool.close(AbstractConnectionPool.java:208) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.DuplexConnectionPool.close(DuplexConnectionPool.java:237) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpDestination.close(HttpDestination.java:385) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.client.HttpClient.doStop(HttpClient.java:260) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:93) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.stop(ContainerLifeCycle.java:180) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStop(ContainerLifeCycle.java:201) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.websocket.client.WebSocketClient.doStop(WebSocketClient.java:371) [bundleFile:9.4.20.v20190813]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection.close(WebSocketConnection.java:159) [bundleFile:?]
at org.openhab.binding.amazonechocontrol.internal.WebSocketConnection$2.run(WebSocketConnection.java:184) [bundleFile:?]
at java.util.TimerThread.mainLoop(Timer.java:555) [?:1.8.0_152]
at java.util.TimerThread.run(Timer.java:505) [?:1.8.0_152]
^C
I’m getting a very similar error to sujitrp’s . It’s coming through every minute or so. And it only started a few days ago. I added the Zigbee binding at about the same time, but that might just be coincidence? I’m not seeing anything in the error messages that makes me think it has anything to do with Zigbee, but I’m not familiar enough with openHAB error messages and coding to know for sure… The only thing specific I see in there is a reference to the Amazon Echo Control binding, but I’ve had that installed for quite a while before this error started coming in.
Anyone have any ideas before I go messing with uninstalling bindings one at a time to see what happens? Or, is there a good way to temporarily disable a binding without losing my existing configurations?
Stopped the Echo binding and the error stopped. It looks like this is a known issue and is also discussed on other threads, such as here: Web Socket Error on AmazonEchoControl binding every 65 seconds. So, I’ll move further discussion of my issue over there, if anything else comes up.
