- Platform information:
- Hardware: _RPI3*
- OS: _Lastest version RAsbian
- Java Runtime Environment:latest version
- openHAB version: 2.5.1
- Issue of the topic:
When running OpenHab I noticed something weird on its behaviour what I have not been able to explain, maybe someone can help me with that.
I create a scene to change modes in a room and use the hueswitch to select the mode that i want. I have two Huew Switches that can be used. When i Handle the hue switch I have created a item called button change that is set to ON ( using .sendCommand) when pressed, and another rule “Item buttonchange changes to ON)” triggers the processing of the button and the modes.
Now this worked all fine , however at some point I had to restart the RPI ( and openhab) because i was working on other rules. After that the buttonchange did not work. I saw in the log that pushing a button on the hueswitch resulted in “button change received ON” but the rule ( "Item buttonchange changes to ON) was not fired.
I then renamed the item in the items and rule file and all was working again , i also renamed it back to the original name and all worked again.
Is there any explnation for this behaviour ?
Thanks in advance , frank
