I moved my Openhab setup from a Windows to a Ubuntu server and am having some issues with the Wemo binding. The openhab.log has entries as follows:
2015-09-06 19:58:29.079 [ERROR] [.o.b.wemo.internal.WemoBinding] - Could not start wemo device discovery
java.net.BindException: Cannot assign requested address
at java.net.PlainDatagramSocketImpl.bind0(Native Method) ~[na:1.7.0_79]
at java.net.AbstractPlainDatagramSocketImpl.bind(AbstractPlainDatagramSocketImpl.java:96) ~[na:1.7.0_79]
at java.net.DatagramSocket.bind(DatagramSocket.java:396) ~[na:1.7.0_79]
at org.openhab.binding.wemo.internal.WemoBinding.wemoDiscovery(WemoBinding.java:179) [bundlefile:na]
at org.openhab.binding.wemo.internal.WemoBinding.wemoCall(WemoBinding.java:295) [bundlefile:na]
at org.openhab.binding.wemo.internal.WemoBinding.execute(WemoBinding.java:103) [bundlefile:na]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:156) [org.openhab.core_1.7.1.jar:na]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:173) [org.openhab.core_1.7.1.jar:na]
Any configurations were taken direct from my old Windows install.
There’s only a single Ethernet interface with a static IP… Any suggestions of where I can look to resolve the issue?
could you please switch to Oracle JAVA 1.7 (or 1.8) cause this is the recommended JRE for openHAB.
There are many reports about problems using a JRE other than Oracle.
Sorry, only just got a chance to work on this. I’ve removed the OpenJDK and installed Oracle Java however the issue still seems to be persisting.
java -version is:
java version “1.7.0_80”
Java™ SE Runtime Environment (build 1.7.0_80-b15)
Java HotSpot™ 64-Bit Server VM (build 24.80-b11, mixed mode)
/var/log/openhab/openhab.log still has entries along the lines of:
2015-09-12 16:55:28.593 [ERROR] [.o.b.wemo.internal.WemoBinding] - Could not start wemo device discovery
at java.net.PlainDatagramSocketImpl.bind0(Native Method) ~[na:1.7.0_80]
at java.net.AbstractPlainDatagramSocketImpl.bind(AbstractPlainDatagramSocketImpl.java:96) ~[na:1.7.0_80]
at java.net.DatagramSocket.bind(DatagramSocket.java:397) ~[na:1.7.0_80]
I’m new to openhab, so I’m not above finding it’s something simple I missed.
Nothing listening on 1900 or 1901 per 'sudo lsof -i -n -P | grep TCP|grep 1900"
I can ping the device at 192.168.1.4 and it is working with the wemo app and IFTTT.
Java version:
java version "1.8.0_91"
Java™ SE Runtime Environment (build 1.8.0_91-b14)
Java HotSpot™ 64-Bit Server VM (build 25.91-b14, mixed mode)
Nothing listening on 1900 or 1901 per 'sudo lsof -i -n -P | grep TCP|grep 190"
Here is the section of the log if it helps:
2016-06-13 19:35:07.918 [INFO ] [t.protocol.internal.TCPBinding] - The characterset will be set to the default vaulue of ASCII
2016-06-13 19:35:07.957 [INFO ] [.service.AbstractActiveService] - HTTP Refresh Service has been started
2016-06-13 19:35:07.979 [ERROR] [.o.b.wemo.internal.WemoBinding] - Could not start wemo device discovery
java.net.BindException: Can’t assign requested address
at java.net.PlainDatagramSocketImpl.bind0(Native Method) ~[na:1.8.0_91]
at java.net.AbstractPlainDatagramSocketImpl.bind(AbstractPlainDatagramSocketImpl.java:93) ~[na:1.8.0_91]
at java.net.DatagramSocket.bind(DatagramSocket.java:392) ~[na:1.8.0_91]
at org.openhab.binding.wemo.internal.WemoBinding.wemoDiscovery(WemoBinding.java:336) [bundlefile:na]
at org.openhab.binding.wemo.internal.WemoBinding.activate(WemoBinding.java:90) [bundlefile:na]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[na:1.8.0_91]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[na:1.8.0_91]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[na:1.8.0_91]
at java.lang.reflect.Method.invoke(Method.java:498) ~[na:1.8.0_91]
at org.eclipse.equinox.internal.ds.model.ServiceComponent.activate(ServiceComponent.java:235) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.activate(ServiceComponentProp.java:146) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:345) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.ServiceReg.getService(ServiceReg.java:53) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceUse$1.run(ServiceUse.java:141) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at java.security.AccessController.doPrivileged(Native Method) [na:1.8.0_91]
at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(ServiceUse.java:139) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:468) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:467) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getService(BundleContextImpl.java:594) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.equinox.internal.cm.ManagedServiceTracker.addingService(ManagedServiceTracker.java:65) [org.eclipse.equinox.cm_1.0.400.v20120522-1841.jar:na]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:932) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:894) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:107) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.registerService(InstanceProcess.java:536) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:260) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.getEligible(Resolver.java:343) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager.serviceChanged(SCRManager.java:222) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89) [org.eclipse.equinox.ds_1.4.1.v20120926-201320.jar:na]
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Executor.run(Executor.java:70) [org.eclipse.equinox.util_1.0.400.v20120917-192807.jar:na]
2016-06-13 19:35:07.980 [INFO ] [.service.AbstractActiveService] - Wemo Refresh Service has been started
2016-06-13 19:35:49.323 [INFO ] [penhab.io.rest.RESTApplication] - Stopped REST API
2016-06-13 19:36:08.291 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.3).
