Seemingly obvious question, but I can’t find an answer!
I’m running OpenHab 3.1.0 currently, but I want to be on the branch that gets the 3.2.0 milestone builds.
Using openhab-config - I’m on the “main” branch, but it says I’m up to date at 3.1.0.
41 | openHAB Stable Install or switch to the latest openHAB Stable Release
| openHAB Milestone Install or switch to the latest openHAB Milestone Build
| openHAB Snapshot Install or switch to the latest openHAB Snapshot Build
But the milestone section throws an error:
There was an error or interruption during the execution of:
"40 | openHAB Related"
Please try again. If the error persists, please read
/opt/openhabian/docs/openhabian-DEBUG.md or
https://github.com/openhab/openhabian/blob/main/docs/openhabian-DEBUG.md how
to proceed.
Seems it was unrelated, but I’ll put my solution here,
I changed debugmode to “on” in /etc/openhabian.conf
I tried the update again and found that it was actually related to the Unifi controller running on the same machine. So, I ran: “sudo apt-get update --allow-releaseinfo-change” on the command line, then tried the “openHAB Milestone” update. And it worked.
I changed debugmode back to “off” in /etc/openhabian.conf
Now the question remains the same - how do I keep updating to the latest milestones. Do I need to go BACK to “41 | openHAB Milestone” or will the “03 | Install openHAB”" option keep me there?
Menu 41 let’s you change the OH tree. You are on a tree as long as you do not change it again.
The other menu entry is to change the release tree for openhabian-config.
