Runging OH on Windows 10
After migrating from OH 3.4.4 to OH 4.1.1 I receive the following message while OH is starting up.
WARN: can’t update etc/config.properties with the generated command shutdown. We advise to manually add the karaf.shutdown.command property.
Can somebody advise where in the config.properties I have to add what exactly.
I found on line 263: karaf.shutdown.port.file=${karaf.data}/port
Many Thanks
