What is wrong in my cfg- eller items-commands? (ESPEasy and openHAB 2)
I am new in this openHAB 2 and ask you for some help with a Sonoff S20 that I try to connect to openHAB 2 that is installed on a Synology NAS.
I have flashed the Sonoff with ESPEasy.
mqtt.cfg has only two lines:
mybroker.url=tcp://192.168.1.51:1883
mybroker.clientId=nas
switch.items contains:
Switch VDrummet "Vardagsrummet" {mqtt=">[mybroker:/BalkongdorrLamp/lightSwitch/Switch:command:ON:1],>[mybroker:/BalkongdorrLamp/lightSwitch/Switch:command:OFF:0],<[mybroker:/BalkongdorrLamp/lightSwitch/Switch:state:ON:1],<[mybroker:/BalkongdorrLamp/lightSwitch/Switch:state:OFF:0]"}
Switch VDrummet "Vardagsrummet" {mqtt=">[mybroker:/BalkongdorrLamp/lightState/Switch:command:ON:1],>[mybroker:/BalkongdorrLamp/lightState/Switch:command:OFF:0],<[mybroker:/BalkongdorrLamp/lightState/Switch:state:ON:1],<[mybroker:/BalkongdorrLamp/lightState/Switch:state:OFF:0]"}
vardagsrummet.things
Thing network:device:switch "BalkongLampa" @ "BalkongdorrLamp" [ hostname="192.168.1.210" ]
demo.sitemap
sitemap demo label="Huset" {
    Frame label="Datum" {
        Text item=Date
 	Frame label="MQTT" {
		Switch item=VDrummet label="Vardagsrummet Balkong"
With Basic UI the switch is visible and can be switched on and off.
With the command
/mosquitto_sub -v -h 192.168.1.51 -t '#'
I can see that the following information is sent:
/BalkongdorrLamp/lightState/Switch 0
/BalkongdorrLamp/lightState/Switch 1
But the switch does not change.
Can somebody tell me what I am doing wrong?
You use the same name 2 times in items
Ok, thanks. I will change that and see if it works.
Just a question. What is the goal of the thing definition?
For switching the sonoff it is not neccersary.
Your correct item definition (if only one!) could be made shorter.
For example:
Switch Sonoff_S20_4 “Sonoff_S20_4” (gLight)
{ mqtt=“>[broker:cmnd/sonoff-084CBE/power:command:*:default], <[broker:stat/sonoff-084CBE/POWER:state:default]” }
It is for the first time that I use openHAB, I thought that I always needed a thing definition.
What does the sonoff-084CBE mean and where do I find this expression for other sonoff devices?
Thanks for your help.
sonoff-084CBE ist just the name off the switch.
I use the topic definition from Theo Arendst see
Here you find a few examples, and it is a good starting point.
Your example works with Tasmota,
but my Sonoff is flashed with ESPEasy.
So please some example for ESPEasy items in openHAB 2.
Hi. 100% work :smile:
Switch   Device_Water_Switch   "Water Valve"	   <water>   { mqtt="<[zbox:/water/sensors/state:state:MAP(1_is_on.map)], >[zbox:/water/sensors/setstate:command:*:MAP(on_is_1.map)]" }
1_is_on.map:
0=OFF
1=ON
NULL=?
on_is_1.map:
OFF=0
ON=1
You should try to avoid staring your MQTT topics with /
Essentially it create an empty “root” topic and although allowed by the MQTT protocol it is not best practice and can lead to errors and/or confusion
Regards
Thanks for your help, guys!
I got it working with the following switch.items:
Switch mySwitch01 "Vardagsrummet"  {mqtt=">[mybroker:/BalkongdorrLamp/gpio/12:command:ON:1],>[mybroker:/BalkongdorrLamp/gpio/12:command:OFF:0],<[mybroker:/BalkongdorrLamp/lightState/Switch:command:OFF:0],<[mybroker:/BalkongdorrLamp/lightState/Switch:command:ON:1]"}
And demo.sitemap:
        Text item=Date
		Switch item=mySwitch01 label="Vardagsrummet Balkong"
It looks like you could create an MQTT loop there
The input “<” mqtt should be state not command
Try changing the last two to:
<[myBroker:/BalkongdorrLamp/lightState/Switch:state:MAP(0off1on.map)
and create a map file named 0off1on.map containing:
0=OFF
1=ON
I tried your proposal and changed switch.items to:
Switch mySwitch01 "Vardagsrummet"  {mqtt=">[mybroker:/BalkongdorrLamp/gpio/12:command:ON:1],>[mybroker:/BalkongdorrLamp/gpio/12:command:OFF:0],<[mybroker:/BalkongdorrLamp/lightState/Switch:state:OFF:0],<[mybroker:/BalkongdorrLamp/lightState/Switch:state:ON:1]"}
But then I loose some functionality: The button on the S20 does not work correct anymore and the icons/button on the BasicUI don’t change color anymore.
However, thank you for your help.
Sorry, I made a mistake. It works with your change.
But it does not change anymore the button on the BasicUI.
Why do you make this extra MAP-file instead of writing “…state:0=OFF” ?
The map traslates the info received from 0 to OFF and 1 to ON
You could use 2 “input” instructions instead
It is very useful when you get information with several values
try adding autoupdate=false at the end of the binding
like this
{ mqtt="whateverthebindingis", autoupdate="false" }
No, it does not change the color of the button on the BasicUI and it does not change when the button is pressed.
In the Sonoff I have the following rule:
on lightSwitch#Switch do
   if [lightState#Switch]=0
      gpio,12,1
   else
      gpio,12,0
   endif
endon
While everything is working correctly with the code in answer 10.
Ok, back to basics
What do you use the sonoff for?
Hi, I use the Sonoff for switching a lamp.
And the next step will be that the lamp will switch on depending of the sunset and switch of depending of the time setting.
Try this one:
Switch mySwitch01 "Vardagsrummet"  {mqtt=">[mybroker:/BalkongdorrLamp/gpio/12:command:ON:1],>;[mybroker:/BalkongdorrLamp/gpio/12:command:OFF:0],<;[mybroker:/BalkongdorrLamp/lightState/Switch:state:0:OFF],<;[mybroker:/BalkongdorrLamp/lightState/Switch:state:1:ON]"}
Hi Vincent, Did you understand that the switch is working fine with the settings from topic 10 from Mar 20?
No sorry.
Can you mark the thread as solved, please?
