I am running on Windows 10, and I get this error in openhab.log file every time my system boots.
I am currently running Build 1568
2019-04-14 02:48:56.744 [INFO ] [org.openhab.ui.paper ] - FrameworkEvent INFO - org.openhab.ui.paper
org.osgi.framework.BundleException: The bundle class path entry "patch/" could not be found for the bundle "osgi.identity; type="osgi.bundle"; version:Version="2.5.0.201904112024"; osgi.identity="org.openhab.ui.paper""
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassPathEntry(ClasspathManager.java:174) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.buildClasspath(ClasspathManager.java:152) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.<init>(ClasspathManager.java:81) ~[?:?]
at org.eclipse.osgi.internal.loader.EquinoxClassLoader.<init>(EquinoxClassLoader.java:43) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.createClassLoaderPrivledged(BundleLoader.java:316) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.getModuleClassLoader(BundleLoader.java:233) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.searchHooks(BundleLoader.java:503) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findResource(BundleLoader.java:600) ~[?:?]
at org.eclipse.osgi.internal.loader.buddy.DependentPolicy.loadResource(DependentPolicy.java:82) ~[?:?]
at org.eclipse.osgi.internal.loader.buddy.PolicyHandler.doBuddyResourceLoading(PolicyHandler.java:157) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findResource(BundleLoader.java:649) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.getResource(ModuleClassLoader.java:200) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.getResource(EquinoxBundle.java:532) ~[?:?]
at org.apache.servicemix.specs.activation.Activator.register(Activator.java:58) ~[?:?]
at org.apache.servicemix.specs.locator.Activator.start(Activator.java:70) ~[?:?]
at org.apache.servicemix.specs.activation.Activator.start(Activator.java:46) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309) ~[?:?]
at org.eclipse.osgi.container.Module.doStart(Module.java:581) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:449) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2019-04-14 02:49:00.123 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'EST5EDT'.
When I go to the basic UI, I see this (notice no switches just check marks, also there is no way to select color!! with the color picker
There have been reports of several issues with the latest builds, not sure if your issue is related or not, try moving to a different build ( something less than 1568). See if that helps and you might also want to check github for similar issues.
019-04-16 11:58:46.474 [WARN ] [.internal.element.HttpContextElement] - Registered http context [null] did not contain a valid http context id
2019-04-16 11:59:00.100 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.12:8080
2019-04-16 11:59:00.102 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.12:8443
2019-04-16 11:59:00.610 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-04-16 11:59:13.917 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-04-16 11:59:15.883 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-04-16 11:59:25.101 [INFO ] [org.openhab.ui.paper ] - FrameworkEvent INFO - org.openhab.ui.paper
org.osgi.framework.BundleException: The bundle class path entry "patch/" could not be found for the bundle "osgi.identity; osgi.identity="org.openhab.ui.paper"; type="osgi.bundle"; version:Version="2.5.0.201904160001""
at org.eclipse.osgi.internal.loader.BundleLoader$2.run(BundleLoader.java:239) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader$2.run(BundleLoader.java:1) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.getModuleClassLoader(BundleLoader.java:236) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$1.run(EquinoxBundle.java:595) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$1.run(EquinoxBundle.java:1) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.getModuleClassLoader(EquinoxBundle.java:588) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.getResource(EquinoxBundle.java:530) ~[?:?]
at org.apache.servicemix.specs.locator.Activator.bundleChanged(Activator.java:95) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:124) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher$1.run(EquinoxEventPublisher.java:1) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:122) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:719) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:511) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:457) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:1001) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1382) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1) ~[?:?]
2019-04-16 11:59:25.153 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-04-16 11:59:25.349 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-04-16 11:59:25.435 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2019-04-16 11:59:25.513 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-04-16 11:59:29.545 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-04-16 11:59:29.550 [INFO ] [core.karaf.internal.FeatureInstaller] - Uninstalled 'openhab-ui-dashboard'
2019-04-16 12:00:06.234 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-04-16 12:00:44.475 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2019-04-16 12:00:44.489 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2019-04-16 12:00:44.503 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
2019-04-16 12:00:44.515 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2019-04-16 12:00:44.538 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2019-04-16 12:07:34.014 [INFO ] [org.openhab.ui.paper ] - FrameworkEvent INFO - org.openhab.ui.paper
org.osgi.framework.BundleException: The bundle class path entry "patch/" could not be found for the bundle "osgi.identity; type="osgi.bundle"; version:Version="2.5.0.201904160001"; osgi.identity="org.openhab.ui.paper""
2019-04-16 12:07:39.571 [WARN ] [.internal.element.HttpContextElement] - Registered http context [null] did not contain a valid http context id
2019-04-16 12:07:46.391 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-04-16 12:07:47.031 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.0.12:8080
2019-04-16 12:07:47.032 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.0.12:8443
2019-04-16 12:07:47.317 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2019-04-16 12:07:47.410 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-04-16 12:07:47.505 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-04-16 12:08:13.706 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '35.953067,-84.10882529999999'.
2019-04-16 12:10:04.612 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2019-04-16 12:10:04.625 [INFO ] [openhab.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2019-04-16 12:10:04.641 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
2019-04-16 12:10:04.658 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2019-04-16 12:10:04.698 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
