It seems like the Tesla-binding is no longer working and also no longer supported, (it requires an app to create a token, and it seems like the app is no longer supported by Tesla, which means it cant create any token).
Now, the binding is still available. But I wonder if thats a great idea, when its not working, and hasnt been working since sometime in may this year?
Also an idea is to take a look at Home Assistant’s integration. There might have been a workaround implementated there, that one could ‘translate’ to Java.
I’ve been meaning to take a look at it - if someone can confirm the HA addon still works, and there is still a way to generate the necessary token, I’ll commit to trying the get the read-only parts of the binding working. (the commands are a no-go they require the updated API and $$$)
I can confirm the Home Assistant Community Store version works fine. Never got Fleet or Powerwall working in HA and I don’t have a wall connector. In the Community Store it is labeled Tesla Custom Integration.
I have a tesla model 3, wall charger in my garage and solar panels, and I want to be able to control the charging of the car base on electricity production of the plant. So I plan to make that possible in OH with the new Tesla Fleet API, I guess the best way will be to change the Tesla Binding, if somebody have a better idea I am open to suggestions.
You actually don’t need the tesla connection for that. You only need to connect to your power meter, if it is sending power to the grid you can start charging. If you car battery state is less than what you have set in the tesla app, the car will charge.
I used to have the tesla binding connected just to read out the battery state of charge but I lost the connection since June, and the principle described works well without it
How do you start/stop the charging? Do you use some wall charger that has API/other connectivity and do a start/stop from it?
I have a wall charger v3 and I think it doesn’t support direct connection, but never pursued this option since I use the tesla connection to pass commands.
