- Platform information:
- Hardware: _RPI4B
- OS: openhabian
- Java Runtime Environment: Don’t know as i am beginner
- openHAB version: 2.5
i cant access openhab configuration file to be able to edit sitemaps ,things … ETC.
but when i map the iIP through windows and enter the the username and password i got empty folder
Hi Muhammad,
sorry for being a bit pedandic: on one hand you wrote
on the other hand you wrote
Could you share
- what exactly you did ( which username, password )
- a screenshot of the empty folder
- a screenshot in case you got an error message
- output of the command: “net use” entered in a windows cmd box
Did you watch the video in this link?
Chances are permission are wrong, unless you used incorrect username.
If you are using the openhabian install you can run the fix permissions in the openhabian-config.
Never mind
I do reinstall of everything and now its going good
but I think it was happened because i was over right samba share and remove it then install again by following the wrong YouTube video
