I have a Strange behavior of my openhab 4.1M3 Installation, which already existed in 4.0.x.
Three of my six modbus-tcp Bridges execute it’s polltask as scheduled polltask. The other three execute the polltask as “one off” polltask? They are all created in the gui as regular Poll?
The problem ist, that the wait time of the “one off” polltasks until they are executed, increases from poll to poll. And that delays also the scheduled polltask, so that they executed after a short time only every 5 min, 10 min , 15 min and so on.
There are no Errors in the logs and the polltask it self have all an execution time of 30-50ms.
All my devices are able to respond to several connections. When i connect in parallel with a modbus tool to the devices, I get error and delays free responses every 200ms. Also openhab shows no Errors during this test.
The only hint my be, that the three bridges with the “one off” polltask, connect to the same serial-modbus-to-tcp device. The Connection have the same Host, but different ports and slave-id.
Also interesting ist, that when disabling one of the three, everything normalizes within minutes and i have no delays anymore.
Any ideas, hints what i can try?
Regards
Boris
hmerk
(Hans-Jörg Merk)
November 17, 2023, 7:19am
2
What Binding are you using ?
Can you please show us your item definitions (code tab).
Wow, fast reply. Thanks.
I am using the standard modbus binding, which comes with openhab.
This is one of the bridges , which execute as “one off” polltask.
There is no change of behavior, when I change reconnectAfterMillis to smaller values or even to 0. All other are defined in the same way.
Regards,
Boris
The Bridge
UID: modbus:tcp:SmartmeterHausBridge
label: Smartmeter Haus Bridge
thingTypeUID: modbus:tcp
configuration:
rtuEncoded: false
connectMaxTries: 1
reconnectAfterMillis: 3600000
timeBetweenTransactionsMillis: 60
port: 503
timeBetweenReconnectMillis: 0
connectTimeoutMillis: 10000
host: Eport-PE11
afterConnectionDelayMillis: 0
enableDiscovery: false’
The Poller
UID: modbus:poller:SmartmeterHausBridge:Leistung
label: Smartmeter Haus Poller Leistung
thingTypeUID: modbus:poller
configuration:
length: 22
start: 52
refresh: 500
maxTries: 3
cacheMillis: 50
type: input
bridgeUID: modbus:tcp:SmartmeterHausBridge
first data
UID: modbus:data:Leistung:LeistungGesamt
label: Smartmeter Haus Leistung Gesamt
thingTypeUID: modbus:data
configuration:
readValueType: float32
readTransform: default
writeTransform: default
readStart: "52"
updateUnchangedValuesEveryMillis: 1000
writeMultipleEvenWithSingleRegisterOrCoil: false
writeMaxTries: 3
bridgeUID: modbus:poller:SmartmeterHausBridge:Leistung
channels:
- id: number
channelTypeUID: modbus:number-type
label: Value as Number
description: Number item channel
configuration: {}
- id: switch
channelTypeUID: modbus:switch-type
label: Value as Switch
description: Switch item channel
configuration: {}
- id: contact
channelTypeUID: modbus:contact-type
label: Value as Contact
description: Contact item channel
configuration: {}
- id: dimmer
channelTypeUID: modbus:dimmer-type
label: Value as Dimmer
description: Dimmer item channel
configuration: {}
- id: datetime
channelTypeUID: modbus:datetime-type
label: Value as DateTime
description: DateTime item channel
configuration: {}
- id: string
channelTypeUID: modbus:string-type
label: Value as String
description: String item channel
configuration: {}
- id: rollershutter
channelTypeUID: modbus:rollershutter-type
label: Value as Rollershutter
description: Rollershutter item channel
configuration: {}
- id: lastReadSuccess
channelTypeUID: modbus:last-successful-read-type
label: Last Successful Read
description: Date of last read
configuration: {}
- id: lastReadError
channelTypeUID: modbus:last-erroring-read-type
label: Last Erroring Read
description: Date of last read error
configuration: {}
- id: lastWriteSuccess
channelTypeUID: modbus:last-successful-write-type
label: Last Successful Write
description: Date of last write
configuration: {}
- id: lastWriteError
channelTypeUID: modbus:last-erroring-write-type
label: Last Erroring Write
description: Date of last write error
configuration: {}
second data
UID: modbus:data:Leistung:295af71471
label: Smartmeter Haus Energie
configuration:
readStart: "72"
writeMaxTries: 3
channels:
- id: number
configuration: {}
- id: switch
configuration: {}
- id: contact
configuration: {}
- id: dimmer
configuration: {}
- id: datetime
configuration: {}
- id: string
configuration: {}
- id: rollershutter
configuration: {}
configuration: {}
- id: lastReadError
configuration: {}
configuration: {}
configuration: {}
Please always mark code with code fences:
your code goes here
These are ‘backticks’ (Accent grave, Shift +` , right from ß at the german keyboard)
Thanks for the hint. I’ve changed the Post.
