I would like to copy or smlink some icons from the classic icon set.
I can use the default isons in th BasicUI and I added a few custom icons to /etc/openhab2/icons/classic
But where are the original icons located?
I cannot find them.
user1@raspi2a:~$ sudo find / -name *.svg
/usr/share/pixmaps/vim.svg
/usr/share/icons/hicolor/scalable/apps/vim.svg
/usr/share/icons/hicolor/scalable/apps/mc.svg
/etc/openhab2/icons/classic/mute-off.svg
/etc/openhab2/icons/classic/mute-on.svg
/etc/openhab2/icons/classic/cd.svg
/etc/openhab2/icons/classic/mute.svg
/etc/openhab2/icons/classic/remote.svg
I know I could download them from the repository, but I am still curious.
wborn
(Wouter Born)
2
They are hidden in a JAR.
# locate org.eclipse.smarthome.ui.iconset.classic
/usr/share/openhab2/runtime/system/org/eclipse/smarthome/extension/ui/iconset/org.eclipse.smarthome.ui.iconset.classic
/usr/share/openhab2/runtime/system/org/eclipse/smarthome/extension/ui/iconset/org.eclipse.smarthome.ui.iconset.classic/0.9.0.b4
/usr/share/openhab2/runtime/system/org/eclipse/smarthome/extension/ui/iconset/org.eclipse.smarthome.ui.iconset.classic/0.9.0.b4/org.eclipse.smarthome.ui.iconset.classic-0.9.0.b4.jar
/var/lib/openhab2/kar/openhab-addons-2.0.0/org/eclipse/smarthome/extension/ui/iconset/org.eclipse.smarthome.ui.iconset.classic
/var/lib/openhab2/kar/openhab-addons-2.0.0/org/eclipse/smarthome/extension/ui/iconset/org.eclipse.smarthome.ui.iconset.classic/0.9.0.b4
/var/lib/openhab2/kar/openhab-addons-2.0.0/org/eclipse/smarthome/extension/ui/iconset/org.eclipse.smarthome.ui.iconset.classic/0.9.0.b4/org.eclipse.smarthome.ui.iconset.classic-0.9.0.b4.jar
There’s an icons
folder inside.
That’s what I thought.
So I will just download the icons from the repository.
Thanks.
rtvb
(Robert)
4
Haven’t tried but couldn’t you just refer to an icon by adding the path within the jar?
davidpace
(David Pace)
5
In case someone looks for the specific location in the GitHub repository:
The icons are located in the openhab-webui project at bundles/org.openhab.ui.iconset.classic/src/main/resources/icons
iegubkin
(Ivan Gubkin)
6
