I’m new to openhab. I want to try out openHab2 with the HABpanel ui a.k.a panelui/uipanel. I downdloaded and installed openhab 2.0.0 b4 offline onto my pi, but the habpanel ui isnt listed. (I enabled “access remote repositories”, “include experimental extensions” and “include legacy 1.x extensions” in extension management just in case).
I googled some pages that said I could download a jar file, but none of the links worked. Most of the links in the threads I have searched through here dont work either. I have browsed the github repositories (There are two pinned repositories at https://github.com/ghys) but I cant find a jar file.
I suspect (although not 100% sure) that HABpanel probably wasn’t included in the beta4 release so either you should change to use the snapshot version, or you should be able to download HABpanel from the snapshot and manually add it to the addons folder.
Hi chris,
I try out the latest snapshot, but I hope it is included, because cant find the jar file anywhere on github (of course it might be my search skills are not up to scratch).
