Where does HABpanel save its icons
I was trying to find the mentioned folder habpanel/assets/icons/ on my RPi3 with no luck
The icons are hard coded as for now. They are not to be found in any directory.
Custom icons is a wanted feature :slight_smile:
You can make a switch with a custom icon by creating a custom template and a butt\on with an icon that you can call from the network or a dir on the openhab server.
thanks :slight_smile:
If you clone habpanel/web github into your openhab html folder you can add icons:
But you are only able to access habpanel through static/habpanel
You can right click on it and “Save image…”
