I have added a ZWAVE plus door sensor to my system to watch the front gate. When I look in PaperUI I can readily see the the status of the sensor
If I try and add it to a sitemap the label prints correctly but the status/state is blank. When I look at the status/state in the Rest API I see it is set to NULL
Thank You ! - That’s exactly what I needed works as intended
I hope you’ll allow me to ask 2 quick follow up questions.
I’m going to add tilt sensors to the system to monitor my garage doors, would the tilt sensors report back using the CONTACT item type as well?
I’ve noticed that the OPEN/CLOSE status of the Gate Sensor is blank after a period of time. If i OPEN or CLOSE the gate the status will update from a "- " to the correct state. My initial assumption is that I need to enable persistence…is this correct? I have yet to enable persistence on my OH system. If this is correct is one of the options easier to implement so I can get a handle on what I need to do?
It depends on the sensor, but I guess it will be a Contact item. In general: you need to use the default item type from the zwave binding, you cannot change it (that was only possible in openHAB1)
