Where is ModBus binding in OH 5.1x?
I am trying to migrate from an OH v4.3.x to v5.1.x system. The old system has the plain ModBus binding installed. But on the new v5.1.x system the Modbus binding is no longer in the Add-On Store. ???
The binding is still there, but the title is wrong…
Issue opened
The “Lambda” binding is “just” named wrong. If you install it, it will result in the base modbus addon and all sub-bindings (E3DC, Studer …) being installed.
But: as the modbus binding grows, it might be a good idea to split the subbindings and make them able to be installed (and found) individually.
I may be wrong but I had an idea that ut had already been done.
See also..
