I cant find file Openhab.cfg in Windows packet in OpenHab2.
I downloaded packet and unzip it.
Google dont answer me.
He say about OpenHab 2 on RaspberriPi.
In OH 2 the openhab.cfg doesn’t exist anymore. For OH 2 bindings it’s not needed anymore, because the configuration is done via things.
In OH2, no longer use openHAB.cfg, in OH2 config file set as it’s individual file, e.g. Matt set conf>services Matt.cfg
The cfg files are just for still supported openhab 1 bindings. The cfg file will be created after adding the binding. But not for OH 2 Bindings.
But not for OH 2 Bindings?
Correct, Official 2.x bindings do not need a separate CFG file. Any settings if needed would be done via the GUI in either PaperUI or Habmin.
Example, the Zwave 2.0 binding. Instead of having a cfg file to set your settings. After you install the binding, you then add your Controller and set the your USB port within the GUI, not via cfg file anymore.
