Zigbee2mqtt.io configuration details mentions the following:
(https://www.zigbee2mqtt.io/information/configuration.html#different-location)
"## Different location #
To specify a different location for the configuration.yaml
(by default inside the data
directory), set the ZIGBEE2MQTT_CONFIG
I believe this variable can be defined in “zigbee2mqtt.service” systemctl file.
Anyone has different idea or experience?
Thanks!
