So I have a corrupt SD Card.
I have some conf. backups and a .img file from Win32 as backup, which I did some months ago.
Question:
The SD Card is still running but after some hours of runtime it just stops and shutsdown.
So I’m still able to get configuration data. Which files can I use to make a reinstallation easier and faster?
Thanks in advantage !
If you only used conf files (.items, .rules, .sitemap) and installed your bindings through addons.cfg (and not just PaperUI), you should only need to copy your backup “conf” files/folders over a brand new OH installation, add any Autodiscovered Things from your Inbox, and mostly be good to go - you will need to go back and change any PaperUI configuration settings (i.e. turning ON/OFF the Simple item mode, setting your default persistence service, setting location, etc…).
Also, get a USB stick and move your root fs to it asap, so the new SD card doesn’t go corrupt in a few months
