I’m seeing various KNX bindings available to set up the integration with OpenHab.
But I miss the overview a bit. Which KNX binding is recommended if you just want a stable, working integration? I have OpenHab 2.1, but I don’t care about “things” or “discovery”, I’m used to working with my .items file.
I think I have these options:
- KNX 1.9 binding that you can select in Paper UI;
- “org.openhab.binding.knx-1.9.0-201611251544” - I’m not sure if this is a more recent/stable version of the aforementioned binding.
- “org.openhab.binding.knx_2.0.0.201702181144.jar” => the 2.0 version. But I’m not sure this is more stable/reliable than the 1.9 version;
Or are there any other/better versions I should consider?
Dries
