Script execution of rule with UID 'room-1' failed: An error occurred during the script execution: Could not invoke method: org.openhab.core.model.script.actions.BusEvent.sendCommand(org.openhab.core.items.Item,java.lang.String) on instance: null in room
Color roomLight_BSLampRGB "RGB" {channel="miio:basic:light:rgbColor"}
Switch roomLight_BSLamp "Lamp" {channel="miio:basic:light:power"}
rule "ROOM roomLight_BSLamp CHANGED"
Item roomLight_BSLamp changed to ON
or Item roomLight_BSLamp changed to OFF
roomLight_BSLampRGB.sendCommand(newState)
Work only this way:
roomLight_BSLampRGB.sendCommand(if (newState == ON) ON else OFF)
As a work around it might be a little simpler to pass newState’s toString instead of using the ternary operator.
...sendCommand(newState.toString)
That should work too. Often what happens when you just see a null error like this it cannot coerce the type of the Item into one that’s useable. In this case I suspect that newState is of type State and perhaps a State can’t be sent as a Command.
Unfortunately Rules DSL isn’t really good at dealing with situations like this.
State Command Object
OnOffType
OnOffType is an Object and a Command and an Object all at the same time. So far so good. But all the engine knows is that newState is of type State and that sendCommand needs something of type Command. The engine isn’t smart enough to look down that type hierarchy tree and then back up the tree to see that it’s also a Command so it just gives up.
I can’t explain why that worked in 2.5. Looking at the code, it shouldn’t have. historicState returns a State and you can’t send a State as a command to an Item.
There have been changes and updates to the Rules DSL engine over that time so perhaps something changed upstream to change how it figures out type.
