Widget: Blinds
Today I made something really cool for you. Widget is for rollershutter.
Features:
  1. Set slider to read only mode if you cant set accurate position
  2. Choose color of your blinds
  3. Widget supports any width. Height should be 2 grids.
Widget image
Widget image
Widget image
Widget designed for 2x1 habpanel dashboard grid
Note: Use 100% of browser zoom
Sources with description: GitHub - andreypopov/habpanel-widget-blinds
popov-blinds.widget.json (6.3 KB)
Amazing, looks really cool and works great. Thx. :+1::+1:
new version, upgrade
Very nice widget I am using now. What I would like to do is translating 0% to “open” and 100% to “close”. How would I do this?
Already made this reverse version. Very soon I will upload.
Now I am using 100% = open, 0% = close, as in Homekit.
thanks for this great widget!
I was not able to figure out what channel to link to an item fo control the percentage using a fibaro roller shutter controller. I’ve tried “shutter position” dimmer channel bot it didn’t work
Nice widget! Using it with pleasure
Hey @andreypopov! great widjet! I’m having a bit of trouble with the STOP command however. Any hints?
With the UP and DOWN, the commands “up” and “down” are translated into 0 and 100%, which is fine, but the STOP does nothing.
Tasmota has the commands “shutteropen” “shutterclose” and “shutterstop” to open, close and stop the blinds, but whatever I set the stop command to, does not reach the controller.
Help?
