What is the path where the widget files are stored?
Widgets are stored in the JSONDB files. You cannot edit those with external editors while openHAB is running.
My openhab3 has completely crashed and I would like to extract these from the system before rebuilding from scratch. I’m getting empty logs, no HTTP access, no SSH access. So I have to rebuild from scratch and would like to salvage as much as possible. Can you point me to the folder where they are stored?
Thanks,
Giri
See here
