Widget graph sometimes doesn't update timeline
i use FullyKioskBrowser to show my solar dashboard.
Works fine, except the graph element.
This doesn’t get updated (very often), so it shows values hours ago.
A reload solves the problem, but it comes back.
But then sometimes its up to date over hours.
All other components on the dashboard work as the should.
This is the code of the graph:
uid: efSolar3_NurGrid
tags: []
props:
  parameters:
    - context: item
      description: GRID Power Item
      label: GRID Power Item FroniusSymoInverter_GridPower
      required: false
      type: TEXT
    - context: item
      description: SOLAR Power Item
      label: SOLAR Power Item FroniusSymoInverter_CurrentSolarYield
      required: false
      type: TEXT
    - context: item
      description: CONSUMPTION Item
      label: CONSUMPTION Item FroniusSymoInverter_LoadPower
      required: false
      type: TEXT
  parameterGroups: []
timestamp: Aug 14, 2024, 10:23:37 AM
component: f7-card
  class:
    - padding-bottom
  style:
    --f7-popover-width: 800px
slots:
  default:
    - component: f7-row
        class:
          - margin-top
        style:
          height: 100%
          top: 5px
          width: 100%
      slots:
        default:
          - component: f7-col
              class:
                - display-flex
                - flex-direction-column
                - align-content-space-around
              width: 100%
            slots:
              default:
                - component: oh-chart
                    chartType: ""
                    label: Leistung
                    period: 12h
                  slots:
                    dataZoom:
                      - component: oh-chart-datazoom
                          type: inside
                    grid:
                      - component: oh-chart-grid
                          containLabel: false
                    legend:
                      - component: oh-chart-legend
                          bottom: 3
                          type: scroll
                    series:
                      - component: oh-time-series
                          color: red
                          gridIndex: 0
                          item: =props.gridPower
                          type: line
                          xAxisIndex: 0
                          yAxisIndex: 0
                          color: yellow
                          gridIndex: 0
                          item: =props.solarPower
                          type: line
                          xAxisIndex: 0
                          yAxisIndex: 0
                    tooltip:
                      - component: oh-chart-tooltip
                          confine: true
                          smartFormatter: true
                    xAxis:
                      - component: oh-time-axis
                          gridIndex: 0
                    yAxis:
                      - component: oh-value-axis
                          axisLabel:
                            formatter: =v => `${v}`
                          gridIndex: 0
Thx in advance and BR
Edi
You can look through this thread for a discussion of refreshing widget and especially charts:
The good news is that your use case is even simpler. You don’t need to create an additional item to drive the key property changes since you already have an item that changes every time you want the graph refreshed (props.gridPower). So your key value probably just needs to look like this:
key: =Math.random() + items[props.gridPower].state
Hi Justin,
and THX.
This works, but the graph gets redrawed completely.
Means it is “flashen” each time.
Is it also possible to force just a “move” of the chart on the timeline instead?
THX and BR
Edi
