Hi, I’m trying to create a widget that lists recordings taken with my camera with the option to play them in a popup.
uid: CAM_Recordings
tags: []
props:
parameters:
- description: Title of The Recording List
label: Title
required: false
type: TEXT
- default: https://xxxx.de/ipcamera/a0470d9ac6/{recording}.mp4
required: true
type: TEXT
- context: item
description: Komma seperated List
label: Komma Seperated List of Recordings
required: true
type: TEXT
parameterGroups: []
timestamp: Apr 3, 2023, 5:11:42 AM
component: f7-card
title: =props.title
slots:
default:
- component: f7-card-content
slots:
default:
- component: oh-repeater
for: size
fragment: true
sourceType: range
slots:
default:
for: list
fragment: true
in: =[items[props.recordings].state.split(",")[loop.size].split(",")[0]]
slots:
default:
- component: oh-button
action: variable
actionVariable: selectedRecording
actionVariableValue: =[items[props.recordings].state.split(",")[loop.size].split(",")[0]]
outline: true
round: false
style:
--f7-button-border-color: var(--f7-card-outline-border-color)
text: =loop.list
popupOpen: .selectetRecording_po
- component: f7-popup
closeByBackdropClick: true
closeOnEscape: true
swipeToClose: true
class:
- selectetRecording_po
slots:
default:
- component: oh-video-card
title: =vars.selectedRecording
url: =props.URL.replace('{recording}', vars.selectedRecording)
class:
- padding
The widget asks for a comma separated list, e.g. video1.mp4,video2.mp4,video3.mp4…
So far, this list is also split up by the oh-repeater and set as a variable after a selection (vars.selectedRecording)
After the recording has been selected, it also starts in an popoup, after I close the popup and want to start the other recording, the first selection is still played, only after clicking on “redraw” and subsequent new selection is the other recording is also played.
Does anyone know what I’m doing wrong ?
Splittet List :
After Klicking the first Video :
After Klicking the second Video :
In the Last Screenshot, the Title of the Video Changed Correctly, but the recording it self ist the “first one”
Only after clicking on “redraw” and subsequent new selection is the other recording is also played.
Without seeing an example of the actual state of your recordings item, it is hard to say exactly what this is doing. However, your second repeater doesn’t seem to be actually repeating anything, because the in property does not appear to be an array. (In fact, it uses the exact same expression that you are using to set the selectedRecord variable.)
You can make the popup itself refresh whenever the variable changes by adding
Thanks for your help,
I have now included the change
but unfortunately the widget editor crashed after clicking on one of the videos, what’s going on there now?
That new code looks much cleaner. You probably don’t even need the key property with that code, it should work without it, I suspect. But, if it’s still giving you trouble, try moving the key property to the video card config instead to just force a refresh of the video card (there may have been some strange race condition between the variable and the popup when the key value was in the popup or base component).
Hi again,
still no luck.
without the key property, and also inside the video Card config: section tested.
same behavior:
I’m not sure at the moment either. I tried a version of your widget code and there are some strange errors in the browser console. I’m going to look into a little further, because I think there may be something buggy going on.
