Platform information:
- Hardware: Raspberry Pi 3
- OS: Openhabian 1.4
- Java Runtime Environment: ?
- openHAB version: 2.2 ?
Issue of the topic: I can contact the raspberry pi 3 over wifi after a few minutes by SSH to see install log, but the install log halts and says it cannot connect to the Wifi SSID I specified!?!
Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
If logs where generated please post these here using code fences:
I was not able to connect to the configured Wi-Fi.
Please try again with your correct SSID and password.
Also check your signal quality. Available Wi-Fi networks:...
