Goal:
Control cheap (China) RGB-LED-Stripes via OpenHAB without the original IR-Remote – instead we’ll use Wifi.
Solution:
Build Wifi-Controller for the RGB-Stripes and send commands via HTTP.
Controller:
Hardware:
To Build the Controller I followed Chris Klinger’s Instructions (german).
To keep things simple I just hardwired the breadboard prototype. From
the available ESP8266 boards I used the LOLIN D1 mini because it
is pretty cheap (~4€ EU/~2$ China) and I can flash it via USB.
Software:
I use the provided software without any notable personal changes. It is
available on Github.
OpenHAB config:
Items:
//Groups
Group:Color:AVG RGB_color "Master Color" <colorwheel> (RGB_color) {alexa="Lighting"}
Group:Switch:OR(ON, OFF) RGB_switch "Master Switch" <switch> (RGB_switch) {alexa="Switchable"}
Group:Dimmer:AVG RGB_dimmer "Master Dimmer" <switch> (RGB_dimmer) {alexa="Lighting"}
//UI Components
Color wifirgb001_color "RGB-001" <lightbulb> (RGB_color) ["Oase"]
Dimmer wifirgb001_dimmer "RGB-001" <lightbulb> (RGB_dimmer) ["Oase"]
Switch wifirgb001_switch "RGB-001" <lightbulb> (RGB_switch) ["Oase"]
//Data Exchange
String wifirgb001_json "RGB-001" <lightbulb> (RGB) ["Oase"] {http=">[*:POST:http://192.168.1.11/api/v1/state:default]"}
//UI Components
Color wifirgb002_color "RGB-002" <lightbulb> (RGB_color) ["Oase"]
Dimmer wifirgb002_dimmer "RGB-002" <lightbulb> (RGB_dimmer) ["Oase"]
Switch wifirgb002_switch "RGB-002" <lightbulb> (RGB_switch) ["Oase"]
//Data Exchange
String wifirgb002_json "RGB-002" <lightbulb> (RGB) ["Oase"] {http=">[*:POST:http://192.168.1.12/api/v1/state:default]"}
//UI Components
Color wifirgb003_color "RGB-003" <lightbulb> (RGB_color) ["Oase"]
Dimmer wifirgb003_dimmer "RGB-003" <lightbulb> (RGB_dimmer) ["Oase"]
Switch wifirgb003_switch "RGB-003" <lightbulb> (RGB_switch) ["Oase"]
//Data Exchange
String wifirgb003_json "RGB-003" <lightbulb> (RGB) ["Oase"] {http=">[*:POST:http://192.168.1.13/api/v1/state:default]"}
Rules:
rule "RGB-001"
Item wifirgb001_color changed or
Item wifirgb001_switch changed or
Item wifirgb001_dimmer changed
var HSBType hsbValue
var int redValue
var int greenValue
var int blueValue
var int brightnessValue
var String myJSON
hsbValue = wifirgb001_color.state as HSBType
redValue = hsbValue.red.intValue
greenValue = hsbValue.green.intValue
blueValue = hsbValue.blue.intValue
brightnessValue = wifirgb001_dimmer.state
myJSON="{\"state\":\""+wifirgb001_switch.state+"\",\"brightness\":"+brightnessValue+",\"color\":{\"mode\":\"rgb\",\"r\":"+redValue.toString+",\"g\":"+greenValue.toString+",\"b\":"+blueValue.toString+"},\"mode\":\"SOLID\"}"
sendCommand(wifirgb001_json, myJSON)
I use a distinct rule for every of my RGB controllers.
One simplification is possible. The controller can also accept HSV values
directly. However, i didn’t know and came up with the above.
I use my RGB-LED-Stripes mainly in rules to display system status or control them
via Alexa. Therefore, my sitemap is pretty short and does only contain the
group of all strips together:
Sitemap
Frame label="RGB" {
Colorpicker item=RGB_color label="RGB-Master"
Slider item=RGB_dimmer label="RGB-Dimmer"
Switch item=RGB_switch label="RGB-Switch"
Final Remarks
This is my first project with OpenHAB and custom build hardware. For my
setting this works already pretty well.
