Prerequisites
- Kernel headers
- Install with "apt-get install linux-headers-$(uname -r)"
- build-essential package
- Install with "apt-get install build-essential"
- Copy the directory containing this file to the build host and change into it
before running any of the following commands
RTL8192CU Wireless Driver for D-Link DWA-121
rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911.tar.gz contains the original
driver package provided in the archive available here:
http://www.realtek.com/downloads/downloadsView.aspx?Langid=1&PNid=21&PFid=48&Level=5&Conn=4&DownTypeID=3&GetDown=false&Downloads=true#2772
Steps to patch and build driver:
tar zxf rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911.tar.gz
cd rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911
patch -p1 < ../rtl8188C_8192C_usb_linux_v4.0.2_9000.20130911-bbb.patch
make
This will build a kernel module called 8192cu.ko
The module can be installed into the kernel module directory structure via:
cp 8192cu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
hostapd Utility for D-Link DWA-121 and DWA-171
wpa_supplicant_hostapd-0.8_rtw_r7475.20130812.tar.gz contains the original
hostapd package provided in the archive available here:
No patching is required
Steps to build hostapd
tar zxf wpa_supplicant_hostapd-0.8_rtw_r7475.20130812.tar.gz
cd wpa_supplicant_hostapd-0.8_rtw_r7475.20130812
cd hostapd
make
This will build the hostapd and hostapd_cli binaries that can be used with the
DWA-121 and DWA-171
