I’m going crazy with this. I have the following thing defined
`Thing wifiled:wifiled:DC4F22876739 [ ip=“[ip removed]”, port=5577, pollingPeriod=30, protocol=“LD382”, driver=“CLASSIC”, fadeDurationInMs=1000, fadeSteps=100 ] // Kitchen
and the following items:
Switch GF_Kitchen_AboveCabinets_Switch "Power" <light> (gKitchen_AboveCabinet_Light) ["Lighting", "Switchable"] {channel="wifiled:wifiled:DC4F22876739:power"}
Dimmer GF_Kitchen_AboveCabinets_Dimmer "Dimmer" <slider> (gKitchen_AboveCabinet_Light) ["Lighting"] {channel="wifiled:wifiled:DC4F22876739:white"}
Color GF_Kitchen_AboveCabinets_Color "Color" <colorpicker> (gKitchen_AboveCabinet_Light) ["Lighting"] {channel="wifiled:wifiled:DC4F22876739:color"}
I have the following test rule:
rule "Kitchen Test"
Item Echo_Office_LastVoiceCommand changed to "kitchen test"
GF_Kitchen_AboveCabinets_Color.sendCommand("255,0,0") //new HSBType("12.5,90.2.90.4"))
When this rule runs (regardless of using RGB or HSBType, I get the following:
2020-01-17 08:07:35.792 [vent.ItemStateChangedEvent] - GF_Kitchen_AboveCabinets_Color changed from 147.61363506317138671875000,100,69.019609689712524414062500 to 255,0,0
2020-01-17 08:07:50.155 [vent.ItemStateChangedEvent] - GF_Kitchen_AboveCabinets_Color changed from 255,0,0 to 147.61363506317138671875000,100,69.019609689712524414062500
Why does it change to what I set it to and then 10 seconds later change back to the previous value (which is the color the app is showing).
Any suggestions are more than welcome!!!
