I got a wifi bulb that works with Magic Home app. I try to put it working in openhab 2.5, but I only can turn it off (I can turn it on, for example…).
This is the log when I try to put it on:
2019-08-28 22:45:10.865 [DEBUG] [iled.internal.handler.WiFiLEDHandler] - Handle command ‘ON’ for wifiled:wifiled:DC4F228B5013:power
2019-08-28 22:45:10.866 [DEBUG] [ternal.handler.AbstractWiFiLEDDriver] - Power ON
2019-08-28 22:45:10.890 [DEBUG] [ternal.handler.AbstractWiFiLEDDriver] - Connected to ‘Socket[addr=/192.168.1.76,port=5577,localport=37867]’
2019-08-28 22:45:10.891 [DEBUG] [ternal.handler.AbstractWiFiLEDDriver] - RAW data sent: ‘71 23 0f a3’
I already try with all device types… (LD382, LD382A and LD686) and the behaviour is the same for LD382A and LD686. For LD382 doesn’t work anything.
Can anybody helps?
Best Regards,
Fernando Gomes
