I am posting this first here on this community to check if I am missing something stupid; but if not then I will open a bug report on GitHub later…
On a Windows system, when I try to run the runtime/bin/update.bat
file to upgrade OpenHAB, the script fails with a “Could not find a part of the path” error as shown in the log excerpt below.
The cause is clear: the script tries to create a backup file with a path + name C:\Users\ ... 20210518.055735-52-rrd4j.cfg
being 275 characters long, that exceeds the Windows maximum 256 character limit.
Does anyone else encounter this problem? And are there any quick fixes?
REINSTALLING version 3.1.0.RC1
Making a backup of your distribution to C:\Users\XXXXXXXX\AppData\Local\Temp\openhab\backup-3.1.0
Creating backup directories in C:\Users\XXXXXXXX\AppData\Local\Temp\openhab\backup-3.1.0
Copying directory conf, userdata and runtime to C:\Users\XXXXXXXX\AppData\Local\Temp\openhab\backup-3.1.0\conf
# Could not backup existing distribution to C:\Users\XXXXXXXX\AppData\Local\Temp\openhab\backup-3.1.0 #
PrintAndReturn : Could not find a part of the path 'C:\Users\XXXXXXXX\AppData\Local\Temp\openhab\backup-3.1.0\userdata\tmp\mvn\org\openhab\addons\features\karaf\org.openhab.addons.featu
res.karaf.openhab-addons-external\3.1.0-SNAPSHOT\org.openhab.addons.features.karaf.openhab-addons-external-3.1.0-20210518.055735-52-rrd4j.cfg'.
At C:\Users\AndrewFG\AppData\Local\Temp\openhab\update\runtime\bin\update.ps1:646 char:14
+ ... exit PrintAndReturn "Could not backup existing distribution to ...
+ CategoryInfo : NotSpecified: (:) [Write-Error], WriteErrorException
+ FullyQualifiedErrorId : Microsoft.PowerShell.Commands.WriteErrorException,PrintAndReturn
