Windows PC remote control (Shutdown, ...)
Hey guys,
I left my apartment over the weekend and just now saw that my PC seems to be active (thanks to the network binding). Does anybody know of a good way to remote control a Windows (10) PC?
I would prefer a dedicated solution. A small application to install on a PC which will then provide some kind of REST interface for all kinds of tasks like shutting down or restarting the PC, starting Kodi, etc.
I just use the exec binding which runs a little script:
net rpc shutdown -f -I 10.x.x.x -U PCXX\Username%password
Obviously, I’ve made it a wrapper and arguments are supplied from the command issued, but this is the important bit. For added HAB-fu, you could also add ICMP ping monitoring and use a Switch item with Wake-on-LAN to turn the computer on and the command above for shutdown. The WoL binding is very easy to implement, and most desktop machines support it.
{wol="10.x.x.0#00:AA:BB:DF:FE:D6", autoupdate="false", exec="<[/bin/sh@@-c@@ping -c 1 10.x.x.x | grep \"packets transmitted\" | sed -e \"s/.*1 received.*/ON/\" -e \"s/.*0 received.*/OFF/\":30000:REGEX((.*))]"}
The above works fine for me.
Cheers,
PelliX
net rpc will work if you run OH on Windows. As you run OH on Linux just as I do, how do you do it there?
EDIT: ok, you can install samba, it’s said to bring the ā€œnetā€ command, but on my Raspian (Jessie) Pi it didn’t…
Thanks for your answers. net rcp is something I already looked into but it’s rather limited and functionality is different between Windows versions, a user with password is needed (I think to remember), …
Anyhow, I’m hoping to find a more modern and straight forward way to control my different systems without the mess of dealing with Windows. A HTTP / REST Interface with configurable options would be amazing. Something has to be available!? Curiously I was not able to find a good solution.
Maybe I’ll have to install an SSH server… still not the set-ready-go solution I’m looking for.
This seems to go in the right direction: Shutter Ā« Products Ā« den4b.com
How about Unified Remote?
It’s an app for Android that allows you to control various devices (like Windows machine).
You simply install server app on PC and you’re ready to go.
AFAIK they have opened their API some time ago.
Maybe it’d be a good candidate for a openHAB Binding?
indeed, I was referring to the setup in which you run OpenHAB on Linux, and ā€˜control’ the shutdown of a Windows computer. Likewise, I use a shell script which ssh’es into Linux workstations to shut them down.
remember), …
Actually, it’s net rpc, as in Remote Procedure Call. Yes, on Windows this is (as far as I know) since NT always a an authenticated action. I think the reasoning for that design should be pretty clear.
Running an SSH server on Windows is possible, and from there you can hack just about anything together with tools ranging from PowerShell to KiXtart to batch files, etc. Some applications expose their own interface for remote control purposes like Media Player Classic, VLC or some Bittorrent clients. If I am not mistaken, the SSH service will also require an authenticated login, though.
Cheers,
PelliX
Hey,
was just nosing around for something else and stumbled upon this:
http://kodi.wiki/view/web_interface
I’m not a kodi user, I use a heavily modified Freevo system in a custom ā€˜media center system’ that I wrote and built a while back, but if I’m not mistaken you can add just about any command to kodi, and operate kodi via HTTP commands. That should cover everything you need, no?
Cheers,
PelliX
i’m using Powershell Server on my Windows 10 PC and the EXEC binding. The solution is not perfect, but it works for me.
Here is an example of 4 commands that i send from OH to start/stop Steam or Plex application.
Rules:
rule "HTPC StartSteam"
Item HTPC_StartSteam received command
var String response = executeCommandLine("/usr/bin/sshpass -p '' ssh -o StrictHostKeyChecking=no username@pc start-process steam.bat", 2000)
logInfo("HTPC_StartSteam", response)
rule "HTPC KillSteam"
Item HTPC_KillSteam received command
var String response = executeCommandLine("/usr/bin/sshpass -p '' ssh -o StrictHostKeyChecking=no username@pc kill -processname Steam", 2000)
logInfo("HTPC_KillSteam", response)
rule "HTPC StartPlex"
Item HTPC_StartPlex received command
var String response = executeCommandLine("/usr/bin/sshpass -p '' ssh -o StrictHostKeyChecking=no username@pc start-process plex.bat", 2000)
logInfo("HTPC_StartPlex", response)
rule "HTPC KillPlex"
Item HTPC_KillPlex received command
var String response = executeCommandLine("/usr/bin/sshpass -p '' ssh -o StrictHostKeyChecking=no username@pc kill -processname 'Plex Home Theater'", 2000)
logInfo("HTPC_KillPlex", response)
the start processes are handled by a batch file and PSEXEC (i put both in the user documents folder at the WIN 10 machine)
Content of plex.bat
psexec -i "c:\program files (x86)\plex home theater\plex home theater.exe"
When I start processes directly throw the executeCommandLine, the processes are starting invisble in the background and not under the logged in user.
My WIN PC has no password and the PowershellServer runs not as service.
Hope this helps.
Guys, I’ve found a satisfying solution to my initial question:
I’m utilizing MQTT (which is quite nice as a protocol already widely used in the home automation area). ā€œWinThingā€ is an MQTT client developed in Java to receive all kinds of Windows system commands, including executing a command, opening a URL or shutting down the system. Have a look:
https://github.com/msiedlarek/winthing
To make this thread complete, here’s a short example, only checking the online state and sending two commands. It’s easily extended.
pc.items:
Switch WZ_PC_Online "PC WinThing Online" { mqtt="<[broker:winthing/system/system/online:state:MAP(truefalse.map)]" }
String WZ_PC_Command "PC Command"
sitemap:
Switch item=WZ_PC_Online
Switch item=WZ_PC_Command mappings=[shutdown="Shutdown", kodi="Start Kodi"]
pc.rules:
rule "PC Command"
	Item WZ_PC_Command received command
	switch (receivedCommand) {
		case "shutdown" : {
			publish("broker", "winthing/system/commands/shutdown", "now")
		case "kodi" : {
			publish("broker", "winthing/system/commands/run", '["C:/Program Files (x86)/Kodi/Kodi.exe"]')
	WZ_PC_Command.postUpdate(NULL)
Hello out there, i am a new beginner to openHAb project.
I“m happy that now my shutter and light configuration is working but now i have a problem with mqqt and win thing.
My goal is to remote shutdown and start 2 Windows 10 PC“s (start maybe with windows login if possible would be great) from openhab
Openhab is running on Synology NAS
Here are the steps i“ve already done. only to be sure thats the right way.
I have installed mosquitto-1.4.11-install-win32 on one of the Windows 10 Pc“s only one first to test (i found a guide i copied the dlls and everything seems to be running fine. It also starts as a Service should work perfect.
Then i start the Winthing.jar manually through windows cmd console (first afterwars it will work automatically)
java -jar -Dwinthing.brokerUrl=tcp://localhost:1883 -Dwinthing.brokerUsername=bob -Dwinthing.brokerPassword=supersecret11 -Dwinthing.clientId=WinThing -Dwinthing.topicPrefix=winthing -Dwinthing.reconnectInterval=5 C:/winthing.jar
then i see in CMD that it seems to be running:
i got status messages from engine: like winthing/system/commands/open and alle the others
and at least: Subscribed, Sending initial Message, Engine Started
So hopefully it looks like its running
I have copied exactly the items the rule and to test also the sitemap from above to the conf folder openhab.
But now its not working.
in events.log i see:
WZ_PC_Command’ received command shutdown
2017-05-20 08:47:00.620 [ItemStateChangedEvent ] - WZ_PC_Command changed from NULL to shutdown
2017-05-20 08:47:00.732 [ItemStateChangedEvent ] - WZ_PC_Command changed from shutdown to NULL
and on openhab.log:
i have nothing
informations: installed openhab 2.1 snapshot and mqqt binding and also action but still not working
maybe you have an answer for me to get this fixed. or other solution for remote pc start/shutdown start progamm etc …
thanks in advance for helping
I
Hey! As always when dealing with MQTT you should use an mqtt client on another device to debug the communication betwen your devices. For PC i can recommend mqtt-spy, for android or iOS you’ll also find apps. Use one of these to troubleshoot the communication.
Yeah, following on from this, I use MQTTBox on Win10 from the Windows Store, and MQTT Dash on Android.
Are you using the 2.0 Exec?
net rpc shutdown works fine if use it from the Terminal, but if I put it in a thing with the exec binding
http://docs.openhab.org/addons/bindings/exec/readme.html#binding-configuration
I get an Error because of the % in -U user%pass
and is there maybe a way where don’t need to put my password in the things file?
Anyway, I’m using openHAB since yesterday on a Raspberry and I love it =D
Cheers,
Mourkain
Hi everybody!
First thanks for the given solution!
I think i done every step like you guys but it seems that i got an problem with the rules above.
Here are the steps i“ve done. Installed and configured mosquitto as broker on my raspberry. As client i tried to use my Windows10 PC, with winthing service. Inside openhab i“ve configured items, sitemap and rules like @ThomDietrich. So far so good.
The connection between mosquitto and my winthing clients works fine! I“ve tested the connection with MQTTlens application from chrome and was so able to send and execute commands on my Windows10 Client. Perfect!
The only thing that doesnt work is the execution from openhab. My log for the rule:
2017-07-06 10:20:31.886 [ERROR] [.script.engine.ScriptExecutionThread] - Rule 'PC Command': An error occured during the script execution: The name 'publish(<XStringLiteralImpl>,<XStringLiteralImpl>,<XStringLiteralImpl>)' cannot be resolved to an item or type.
I also tried to create an item like:
 Switch WZ_Test "PC WinThing test" { mqtt=">[mosquitto:winthing/desktop/commands/close_active_window:command:close_active_window:1]"}
but also no success. Perhaps someone can help me with the mqtt commands in openhab.
Have you installed publish action?
http://docs.openhab.org/addons/actions/mqtt/readme.html
thanks! Finally it works :slight_smile:
@ThomDietrich can you share how you integrated this into Habpanel? Thanks
I did not. :grinning_face_with_smiling_eyes:
