I’m new to this community and dont know if this is the right way to go but i want to contribute a bit.
Im working on an powershell update script for windows
i’ve set up a little draft:
$openhabinstallfolder = "C:\openhab-2.4.0_test" #the directory of the current installation
$backupdir = "c:\temp\bckdir\" #directory to backup the current installation
if ($openhabinstallfolder.Substring($openhabinstallfolder.length - 1, 1) -eq "\")
$openhabinstallfolder = $openhabinstallfolder.Substring(0, $openhabinstallfolder.length - 1)
$filestoremovehash = @{
"files" = "userdata\etc\branding.properties", "userdata\etc\branding-ssh.properties", "userdata\etc\config.properties", "userdata\etc\custom.properties", "userdata\etc\custom.system.properties", "userdata\etc\distribution.info", "userdata\etc\jre.properties", "userdata\etc\org.openhab.addons.cfg", "userdata\etc\org.ops4j.pax.url.mvn.cfg", "userdata\etc\overrides.properties", "userdata\etc\profile.cfg", "userdata\etc\startup.properties", "userdata\etc\system.properties", "userdata\etc\version.properties"
"startwith" = "userdata\etc\org.apache.karaf"
"dirs" = "userdata\cache", "userdata\tmp", "runtime"
if (test-path "$openhabinstallfolder\runtime\bin\karaf.bat")
write-host "Checking if Openhab is running"
if ((Get-Process | where-object { $_.ProcessName -eq "openHAB2-wrapper" }).count -eq 0)
Write-Host "Creating backup"
if (((Test-Path $backupdir) -eq $false))
New-Item -ItemType directory -Path $backupdir -Force
Copy-Item -Path $openhabinstallfolder -Destination $backupdir -Recurse -Verbose
foreach ($filetodelete in $filestoremovehash.files)
if((Test-Path "$openhabinstallfolder\$filetodelete") -eq $true){
Remove-Item "$openhabinstallfolder\$filetodelete" -Force -Verbose
else
Write-Host "Skipping $openhabinstallfolder\$filetodelete"
foreach ($startwith in $filestoremovehash.startwith)
Remove-Item "$openhabinstallfolder\$startwith*" -Force -Verbose
foreach ($dirstodelete in $filestoremovehash.dirs)
Remove-Item "$openhabinstallfolder\$dirstodelete" -Force -Recurse -Verbose
write-host "Starting installation process"
$json = (Invoke-WebRequest -UseBasicParsing -uri https://ci.openhab.org/job/openHAB-Distribution/api/json).content | ConvertFrom-Json
$selectedbuild = (Invoke-WebRequest -UseBasicParsing -uri "$($json.lastBuild.url)api/json").content | ConvertFrom-Json
$selectedartifact = ($selectedbuild.artifacts | where-object { $_.filename -like "*.zip" })
$downloadpath = $selectedbuild.url + "artifact/" + $selectedartifact.relativePath
write-host "Downloading latest snapshot"
Invoke-WebRequest -UseBasicParsing -Uri $downloadpath -OutFile "$env:temp\$($selectedartifact.filename)"
$expandfolder = "$env:temp\$($($selectedartifact.filename).substring(0, $($selectedartifact.filename).length - 4))"
write-host "Expanding archive"
Expand-Archive -Path "$env:temp\$($selectedartifact.filename)" -DestinationPath $expandfolder -Force
Set-Location $expandfolder
$files = get-childitem $expandfolder -Recurse -file | resolve-path -Relative
foreach ($file in $files)
$destination = "$openhabinstallfolder\$($file)"
if (test-path $destination)
write-host "File $file already exists, skipping" -BackgroundColor Yellow
else
if ((test-path $destination.Substring(0, $destination.LastIndexOf("\"))) -eq $false)
write-host "Creating folder $($destination.Substring(0, $destination.LastIndexOf("\"))) " -BackgroundColor Green
New-Item -ItemType directory -Path $destination.Substring(0, $destination.LastIndexOf("\"))
write-host "Copying $file to $destination " -BackgroundColor Green
Copy-Item -Path $file -Destination $destination -force
write-host "Cleaning up"
Set-Location $env:HOMEPATH
Remove-Item $expandfolder -Recurse -Force
Remove-Item "$env:temp\$($selectedartifact.filename)" -Force
Else
Write-host "Openhab is running please shutdown before running this script" -BackgroundColor Red
else
write-host "Openhab installation folder is not correct" -BackgroundColor Red
Does anyone has any comments or can someone test this?
