Wired opening sensor integration
Hi There,
I am running OpenHab 4.2.1 on a Raspberry Pi 4 4GB and at the moment I am about to plan the wiring / smarthome of a single family house. The wiring of the building has still to be done, so that is not a problem, but an opportunity.
I tried to find an easy, quite cheap and energy saving solution for each task :
So far I have:
  • lights, power outlets and shutters via z- wave ( not all of them, for sure. Most stuff will be wired and prepared for a receiver. Most shutters will be wired as well, just what I need )
  • sun and wind for shutters / raffstores via Eltako and FGBS-222 ( 3 imputs )
  • Fingerprint on ESP 32 with Door Bell and Opener via mqtt and FGBS Smart Implant ( 2 outputs )
  • Axis Camera that thats pictures on ringing / opening and send it via Pushover
  • wired 12V smoke sensors with wired sirene with battery backup via FGBS-222 ( 1 input )
  • 12 DS18B20 sensors via FGBS-222
  • Garage door opener via 2 third FGBS-222 with 2 inputs ( endlimit ) and 1 output ( toggle switch ) as well as numeric keypad with RFID
  • some 12V Slim Relais, mostly for FGBS, movement, smoke
It works quite well on a small board so far.
Now I want to add some opening sensors, at best for all windows, maybee doors…
And now, I am looking since some days without finding a nice solution.
My best thought is to have 20-30 12V slim relais ( I think, that would work quite good with low energ consumption ), an esp32 withsome I2C extensions and mqtt
But then I would have about 40-60 rules, just for this stuff. Is this too much?
Is there a better way? Could I use the RaspBerry itself? Should I use a wireless solution?
Thank you very much for your time
Personally, I’d just use Zigbee contact sensors. I’m very happy with IKEA’s new PARASOLL sensors.
Nothing wrong with hardwiring, but I suspect that will cost you a lot more for all of the installation work.
Hi rpwong,
thank you very much for your input.
The price for 1 window is lower than 5 €:
Opening Sensor
Slim Relais
As I use wires like that, there are no special costs for those 2 wires from the window to the DIN rail:
Wire Example
If you are creating 40-60 rules “just for this stuff” you are likely missing opportunities to combine logic and rules. You should be able to write one rule to handle all of the open sensors.
Since you have opportunity to run wires, you have the opportunity to avoid battery powered devices. If you run low voltage wires like you link to to each window you can use cheap magnetic reed sensors (a pack of 5 < $10 US) and an RPi, ESP, Arduino, etc. These will work with standard 3.5v output by the RPi so no voltage converters would be required.
The come in all sorts of form factors. My favorite for doors are the ones the fit in a hole you trill in the top of the door.
Also if you’ve several sensors in one location you can run one power cable that you split to each of the sensors and then only need one wire coming back for each sensor.
Of course you’ll need to compare the up front cost of running the wires with the long term time and cost of keeping up with battery replacement.
I was referring to labour costs for installation, but that wasn’t clear. If you’re doing it yourself, labour isn’t a cost factor, just a time factor.
Thank you very much for your reply.
Yes, I was planning to use some of those cheap reed contacts / magnetic sensors. I am still searching for a product, that fits in the window frame/reveal ( like the slim opening sensor io from Somfy ).
I do not really like batteries, but as there will be enough wires for sure for everybody.
Do you think, those 3.3V from RaspBerry’s GPIO ( maybe with I2C extension ) are powerful enough? There are several dozen meter on 3 floors. This was the only reason, I was choosing a higher voltage.
So my further questions would be:
  • is the voltage of 3.3V enough for those long ways through the whole house?
  • if I use my RaspBerry directly, I will need the GPIO binding. Is my “problem” with logic and rules the same here? Maybe you could give me a good hint for the one rule to rule them all?
  • it should not make any difference, if I use an I2C bus to have more PINs?
@rpwong my bad. I didn’t explain it good enough. I have 3 friends ( retired electricians ) to do the labour stuff ( they say, 1 day only ) and I get the wires and needed Fibaro devices for net purchase or free. The rest of the stuff is already purchased and mounted on a test wall.
My main goals are to stay as simple, reliable and cheap as possible, hopefully energy saving and that kind of automated, that I don’t have to intervene manually. I’m open for every suggestion
So what you’re saying is it’s a beer cost? :wink:
I would guess no, due to voltage drop. This might be helpful.
I have a pair of magnetic reed sensors on my garage doors that I run off of an RPi 3. Ran them off of an RPi 1b before that. They work fine.
There was a security system installed in my house prior to moving in and there were a bunch of sensors about with wires all leading to the basement. I was able to get the reed sensors working with the 3.5v GPIO on an RPi 0w.
Note, I’m not doing I2C. Each sensor is direct wired to the GPIO and I use GitHub - rkoshak/sensorReporter: A python based service that receives sensor inputs and publishes them in various ways. to publish their state to MQTT. I don’t know if I2C will impose other problems/ restrictions.
If I were to do it over again (and I plan on doing so some day), I’d use ESP8266 or ESP32 instead of RPis to push the sensor states to MQTT. But I’ve been running with the RPis for about seven or eight years now without problem.
Not necessarily. See above for one solution. There’s several other options. You don’t need to mess with the GPIO stuff directly by OH. That’s not always practical anyway (e.g. the wires may not be where you want to run OH).
As for one rule, it largely depends on what you want to do in that rule. See Topics tagged designpattern for lots of different ways to make a rule to handle lots of different Items.
For one simple example, let’s say you want to send an alert if a sensor remains open for too long.
  1. Put all the open/closed sensors into a Group
  2. Create a rule that is triggered by any member of the Group created in 1 changing.
  3. In Blockly using openHAB Rules Tools [4.1.0.0;5.9.9.9] - Block Libraries - openHAB Community (which implements a lot of the Design Pattern posts):
It doesn’t matter if you have one sensor or 100, this one rule will log out if any one of them remains open for more than five minutes.
In JS Scripting the same rule, without using the OHRT library’s TimerMgr would look something like:
var timer = cache.private.get(event.itemName);
if(event.itemState.toString() == "OPEN") {
  timer?.cancel();
  cache.private.put(event.itemName, actions.ScriptExecution.createTimer(time.toZDT('PT5M'), (itemLabel) => {
    console.info(itemLabel + ' has been open for more than five minutes!');
  }, items[event.itemName].label);
else {
  timer?.cancel();
These ten lines of code can handle all your open sensors (assuming you want them all to behave the same way). Note, I’m using a brand new feature added to the openhab-js above that allows us to pass variables into the timer function.
There are also rule tempaltes that can handle these. For example, you can install and instantiate Threshold Alert and Open Reminder [4.0.0.0;5.9.9.9] - Rule Templates - openHAB Community with:
  • Triggering Group: the Group created in 1 above
  • Threshold State: OPEN
  • Alert Delay: PT5M
  • leave the rest of the properties at their defaults
This handles all your open sensors and you don’t have to code the rule. And as a bonus the rule template supports repeating the reminder, customized properties on a per Item basis, and a do not disturb period, all for free. All you need to do is write the code that responds (e.g. send the alert) when the sensor is OPEN for too long.
It depends on the distance of course. I can say they work for me with wires in the 30’-45’ range (really rough estimate, I can’t say I really know how these wires are routed). At least the magnetic reed sensors do. Since they operate with a simple open/close circuit just enough voltage needs to get through for the GPIO to pick up (1.8v for RPi, don’t know for ESPs). We aren’t powering LEDs here, just detecting if the circuit is open or closed so we have lots of room for voltage drops.
Feeding in what I know about the RPi GPIO specs (3.5v, 50mA) assuming PVC conduit, 8AWG copper wiring, and DC power of course, there’s only a drop of 0.11% in voltage over 500’. Obviously @derHerrdesSchreckens should put in their actual wire specs but as I mess around I can’t get more than a percent drop over 500’.
tl;dr: you it’s probably going to work for simple reed sensors.
I guess, using this guthub sensor reporter is far beyond my skills at the moment, but thank you very much for your input on the rules side. Maybe, I look for templates first and have another honest look at blockly. To be honest, that was a little bit too much, I will read this post and the links several more times in the future, I think.
This should make one think :slight_smile:
Regarding the calculator, AWG8 is 8mm². We should better look at AWG18, which is similar to an YSTY X x X x 0,8mm, which is a kind of good standard. In the estimated resistance part, we get around 35m until the voltage falls under 1.8V. That’s a really nice distance in theory. Per floor, I guess it will be more than 35m.
Maybe I will test it with some cable that I have here for testing purposes. But since all the wires will meet again in a fuse box, it is no problem for me to change to 12V or find a good spot for the RaspBerry, if there is a chance to use it directly.
The wire specs - without big thinking would be 3 kind of wires:
NYM 5x1.5 for 230V
YSTY 2x2x0.8 for the single devices
YSTY 10x2x0.8 for the common ways to the floors and rooms ( maybe 20x2x0.8 )
If you can set up and user openHAB, you can set up and use sensorReporter. In most respects it’s much simpler to use than OH is. And while I use it with MQTT, it has a plug-in to update Items in OH directly, nothing else is required.
And of course you have the original author of it right here if you run into trouble to ask questions from.
There’s an installation script now that installs everything need to run. Once installed you just need a relatively simple config. Here’s the config that runs my garage door openers (two openers, two reed sensors, MQTT configuration).
Logging:
    File: /tmp/sensorReporter.log
    MaxSize: 67108864
    NumFiles: 10
    Syslog: YES
    Level: INFO
Connection1:
    Class: mqtt.mqtt_conn.MqttConnection
    Client: cerberos
    User: username
    Password: password
    Host: MQTT_broker_host
    Port: 1883
    TLS: NO
    Keepalive: 60
    RootTopic: sensor_reporter/cerberos
    Level: INFO
SensorLargeGarageDoor:
    Class: gpio.rpi_gpio.RpiGpioSensor
    Connections:
        MQTT:
            Switch:
                StateDest: garagedoor1/state
    GpioChip: 0
    Pin: 7
    PUD: DOWN
    Btn_Pressed_State: HIGH
    EventDetection: BOTH
    Level: DEBUG
SensorSmallGarageDoor:
    Connections:
        MQTT:
            Switch:
                StateDest: garagedoor2/state
    GpioChip: 0
    Pin: 8
    PUD: DOWN
    Level: DEBUG
ActuatorLarageGarageDoor:
    Class: gpio.rpi_gpio.RpiGpioActuator
    Connections:
        MQTT:
            CommandSrc: garagedoor1/cmd
    GpioChip: 0
    Pin: 17
    InitialState: ON
    SimulateButton: True
    Level: DEBUG
ActuatorSmallGarageDoor:
    Connections:
        MQTT:
            CommandSrc: garagedoor2/cmd
    GpioChip: 0
    Pin: 22
    InitialState: ON
    Level: DEBUG
That’s it. with that I can configure OH to subscribe to an MQTT topic and see when the doors are OPEN or CLOSED and send a message to a different MQTT topic to trigger the garage door openers. It’s even simpler with a Homie config as OH can automatically discover those and of course, sensorReporter can talk to OH directly instead of going through MQTT.
that sounds uplifting. I will receive some I2C expanders these days and then I try to set up the sensorreporter. I saw an I2C folder there.But “installation script” really sounds way different now.
I just did a quick try with a 0.8mm² cable, 10m, one contact. Worked very well on the ESP itself. But this needs to be more stressed out.
I totally know to whom I’m talking, I don’t type, but I read quite a bit on these sites. It is not the first time,you gave me a good hint. You helped me dozen times before. Thank you. I will come back after some more trial & error.
I have used a few of these in my new house. Very easy. Wires run to every window, doors, and multiple locations around the house for PIR/mm sensors.
Hi, good evening,
Thank you very much for your input, but this is way too expensive. I hope to remain below 999 € altogether.
@rlkoshak I indeed managed to install sensorReporter. It was my first github- Installation. So, I’m siiting here since many hours and what I got now:
sensorReporter starts fine, sends the “online” message to /status and once the state of the PIN. After that, I receive no reaktion when changing PINs.
May 23 00:37:34 raspberrypi24 python[8216]: INFO - [RpiGpioSensor]  KingPin short button press occurred on Pin 18 was pressed for 49.584125 seconds
May 23 00:38:23 raspberrypi24 python[8216]: INFO - [RpiGpioSensor]  KingPin Pin 18 changed from 1 to 0 (= CLOSED)
In the Logs, I can see the change, but not transmission via mqtt. Here is my yml
Logging:
    Syslog: yes
    Level: DEBUG
Connection1:
    Client: sensorReporter
    User:
    Password:
    Host: 192.168.0.24
    Port: 1883
    Keepalive: 10
    TLS: no
    Level: DEBUG
Sensor KingPin:
    Connections:
        MQTT:
            StateDest: mqtt-test
    GpioChip: 0
    Pin: 18
    PUD: UP
    Btn_Pressed_State: LOW
    Level: DEBUG
I’m almost there, but I cannot figure out, which little thing I missed.
With the I2C- Adapters, I’m half done, too. I managed it to solder and attach to the RaspBerry and was able to find something with “i2cdetect” on place 21. But I don’t know yet how to find out the names of the Pins and integrate them into sensorReporter.
I will be in holidays for some days!
Are you using MQTT Explorer to monitor the message traffic on your MQTT Broker. That’s going to be very useful when debugging MQTT stuff as it independently shows the messages published. From there you can narrow down problems to either the publisher (i.e. sensorReporter) or the subscriber (i.e. openHAB).
Though if you are not seeing logs from sensorReporter then it’s likely that the the problem lies there. The library sensorReporter uses to interact with the GPIO pins was recently swapped out for a newer and maintained one.
How are you testing (i.e. “changing”) the pins? What do you have wired to GPIO pin 18?
You’d use the I2C plug-in, not the RpiGpioSensor plugin. That module was actually contributed by others and I personally have no experience with I2C. And I2C seems to not be all that generic so it might require additional code to implement. But over all, you won’t need to mess with mapping GPIO pins for that. You’ll just wire the I2C to pin 4 which is the I2C pin and configure an I2C plug-in to handle that.
I installed mqtt reporter on my desktop now. I can see:
IP/status
IP/mqtt-test
as topics. ONCE the sensorReporter is started, the values are published, but when I change the PIN, there is no further action. When stopping the service, I receive the status “OFFLINE” as well.
I “change” the PIN by connecting it to GND. I use the GPIO- Binding simultaneously and I can see the PIN changing from “OFF” to “ON” as well as when I look into the logs of the sensorReporter ( last line is the change from “CLOSED” to “OPEN” without an mqtt message published.
pi@raspberrypi24:~ $ sudo systemctl status  sensor_reporter.service
â—Ź sensor_reporter.service - Reports status and sensor readings over MQTT and openHAB REST
     Loaded: loaded (/etc/systemd/system/sensor_reporter.service; disabled; preset: enabled)
     Active: active (running) since Mon 2024-05-27 15:05:12 CEST; 8s ago
   Main PID: 16325 (python)
      Tasks: 5 (limit: 3910)
        CPU: 1.732s
     CGroup: /system.slice/sensor_reporter.service
             └─16325 /srv/sensorReporter/bin/python sensor_reporter.py sensor_reporter.yml
May 27 15:05:14 raspberrypi24 python[16325]: DEBUG - [RpiGpioSensor]  KingPin will report to following connections:
                                             MQTT:
May 27 15:05:14 raspberrypi24 python[16325]: DEBUG - [RpiGpioSensor]  KingPin configured values:
                                             DEFAULT:
                                             - OPEN
                                             - CLOSED
May 27 15:05:14 raspberrypi24 python[16325]: DEBUG - [MqttConnection] Published message CLOSED to sensor_reporter/mqtt-test retain=False
May 27 15:05:14 raspberrypi24 python[16325]: DEBUG - [sensor_reporter] 1 sensors created
May 27 15:05:14 raspberrypi24 python[16325]: DEBUG - [sensor_reporter] Creating polling manager
May 27 15:05:14 raspberrypi24 python[16325]: DEBUG - [sensor_reporter] Created, returning polling manager
May 27 15:05:14 raspberrypi24 python[16325]: INFO - [PollManager] Starting polling loop
May 27 15:05:14 raspberrypi24 python[16325]: DEBUG - [MqttConnection] on_publish: Successfully published message <paho.mqtt.client.Client object at 0x7f91483d10>, None, 4
May 27 15:05:16 raspberrypi24 python[16325]: INFO - [RpiGpioSensor]  KingPin Pin 18 changed from 0 to 1 (= OPEN)
When I stop the service, pull the PIN 18 UP or DOWN ( connecting or disconnecting from GND ) and start sensorReporter again, the state of the PIN is published again. Once.
Do I have to configure the polling manager in any way through the yml file?
I was trying to work with I2C plugin, but I could not figure out, how this should work. The plugin is for 3 kind of special devices only? I think, the wiring is done correctly. Can you give me a hint, which plugin or additional code could bring me further?
You can try to configure the Poll parameter to something like 0.05 or 0.1. That should disable the event detection and instead cause sensorReporter to just poll for the current state. I’m not sure what could be going wrong but
Edit: One thing occurs to me. You have sensorReporter and openHAB’s GPIO add-on connected to the same GPIO pin at the same time? Two different pieces of software connected to the same hardware at the same time almost never works as expected, if at all. Make sure that the GPIO binding is not enabled at the same time, maybe even test with openHAB completely shut down.
For I2C I can’t be of any help. I do believe that I2C isn’t generic and will require specific code to handle. Like I said above, I didn’t contribute the I2C stuff to sensorReporter and have no personal experience with it. Based on the docs though I agree that the I2C plugin is for specific devices, not generic, meaning you’d need to code for your own specific devices.
  • I shut down OpenHab
  • I replaced the entry “EventDetection: BOTH” by “Poll: 0.05”
I receive the same result:
     Active: active (running) since Tue 2024-05-28 13:00:26 CEST; 3s ago
   Main PID: 18823 (python)
        CPU: 1.613s
             └─18823 /srv/sensorReporter/bin/python sensor_reporter.py sensor_reporter.yml
May 28 13:00:27 raspberrypi24 python[18823]: INFO - [RpiGpioSensor]  KingPin configured button press events, with short press threshold 0.002, long press threshold 0.0 and pressed state LOW
May 28 13:00:27 raspberrypi24 python[18823]: INFO - [RpiGpioSensor] Configured RpiGpioSensor  KingPin: chip 0, pin 18 with PUD UP
May 28 13:00:27 raspberrypi24 python[18823]: DEBUG - [RpiGpioSensor]  KingPin will report to following connections:
                                             MQTT:
May 28 13:00:27 raspberrypi24 python[18823]: DEBUG - [RpiGpioSensor]  KingPin configured values:
                                             DEFAULT:
                                             - OPEN
                                             - CLOSED
May 28 13:00:27 raspberrypi24 python[18823]: DEBUG - [MqttConnection] Published message CLOSED to sensor_reporter/mqtt-test retain=False
May 28 13:00:27 raspberrypi24 python[18823]: DEBUG - [sensor_reporter] 1 sensors created
May 28 13:00:27 raspberrypi24 python[18823]: DEBUG - [sensor_reporter] Creating polling manager
May 28 13:00:27 raspberrypi24 python[18823]: DEBUG - [sensor_reporter] Created, returning polling manager
May 28 13:00:27 raspberrypi24 python[18823]: INFO - [PollManager] Starting polling loop
May 28 13:00:27 raspberrypi24 python[18823]: DEBUG - [MqttConnection] on_publish: Successfully published message <paho.mqtt.client.Client object at 0x7fa47a3d10>, None, 4
May 28 13:00:38 raspberrypi24 python[18823]: INFO - [RpiGpioSensor]  KingPin Pin 18 changed from 0 to 1 (= OPEN)
May 28 13:00:38 raspberrypi24 python[18823]: WARNING - [RpiGpioSensor]  KingPin expected contact closed before release. 'Btn_Pressed_State' is probably configured wrong for Pin: 18
May 28 13:01:13 raspberrypi24 python[18823]: INFO - [RpiGpioSensor]  KingPin Pin 18 changed from 1 to 0 (= CLOSED)
May 28 13:01:19 raspberrypi24 python[18823]: INFO - [RpiGpioSensor]  KingPin Pin 18 changed from 0 to 1 (= OPEN)
May 28 13:01:19 raspberrypi24 python[18823]: INFO - [RpiGpioSensor]  KingPin short button press occurred on Pin 18 was pressed for 6.512753 seconds
May 28 13:01:24 raspberrypi24 python[18823]: INFO - [RpiGpioSensor]  KingPin Pin 18 changed from 1 to 0 (= CLOSED)
May 28 13:01:28 raspberrypi24 python[18823]: INFO - [RpiGpioSensor]  KingPin Pin 18 changed from 0 to 1 (= OPEN)
May 28 13:01:28 raspberrypi24 python[18823]: INFO - [RpiGpioSensor]  KingPin short button press occurred on Pin 18 was pressed for 4.508448 seconds
May 28 13:02:39 raspberrypi24 python[18823]: INFO - [RpiGpioSensor]  KingPin Pin 18 changed from 1 to 0 (= CLOSED)
May 28 13:02:46 raspberrypi24 python[18823]: INFO - [RpiGpioSensor]  KingPin Pin 18 changed from 0 to 1 (= OPEN)
May 28 13:02:46 raspberrypi24 python[18823]: INFO - [RpiGpioSensor]  KingPin short button press occurred on Pin 18 was pressed for 7.014061 seconds
May 28 13:02:49 raspberrypi24 python[18823]: INFO - [RpiGpioSensor]  KingPin Pin 18 changed from 1 to 0 (= CLOSED)
The state of the PIN never gets published via mqtt, but once, when starting the sensorReporter. Maybe you can give me a hint, where the publish via mqtt takes place? Maybe a friend of mine can have a closer look.
As soon as I am back, I could try sensorReporter on my other RaspBerry 3?
For the I2C Expander, I tried to make a file “pcf8575.py”, but I could not figure out, where you import those files. Is it not within “sensor_reporter.py”?
I don’t think it’s the publish that’s the problem. It’s detecting the change on the GPIO. That first publication comes when sensorReporter first starts up. But after that point it’s not detecting a change of the GPIO pin so it doesn’t report anything.
If it were an MQTT problem, you wouldn’t get the initial messages.
Based on the logs though it is seeing the GPIO pins changing but it’s treating them as a button press. That’s not really what you want. You don’t want it to sit on the events until it determines a button was pressed and released. Eliminate that “Btn_Pressed_State” parameter.
The warning might point to what’s going wrong as well. You’ve set the “Btn_Pressed_State” to “LOW” which, based on the warning, is most likely wrong for your sensor. sensorReporter expects a button to not be being pressed when it first starts up.
But you don’t really want to do button press detection in the first place so get rid of that parameter and sensorReporter should treat the events as a discrete events rather than trying to figure out if it’s a short press or a long press or a double press of a button.
I’m not sure why I have the Btn_Pressed_State configured on my sensors. It’s probably left over form a years ago debugging session that I never removed.
If for some reason you do want to treat this sensor like a button, change the Btn_Pressed_State to HIGH. That’s what the warning in the logs is telling you is wrong.
I’m going from memory here so I might miss a step. If you run into trouble let me know.
  1. Assuming this I2C represents only sensors you need to create a class that inherits from core.sensor
  2. You need to implement at least the publish_state method. This is the method that is called publish the current state of the sensors to the registered Connections. You may need to implement a cleanup method as well, which gets called when sensorReporter is shutting down.
  3. Put your code under the i2c folder (it doesn’t really matter where you put it but that’s a convenient place to put it).
  4. Everything else is handled for you. sensorReporter uses reflection to identify and load the plug-ins. You just need to add a section to your config YAML. You’d use i2c.pcf8575 as the Class. The Connections section will be the same as you are using now for the GPIO sensor. Level sets the logging level. Everything else gets passed into the _init method of your class as the third argument. If you look at the other sensors you’ll see we call that dev_cfg. So if you had a parameter Foo you’d access that in the _init method using dev_cfg["Foo"].
Sensor KingPin:
    Class: i2c.pcf8575
    Connections:
        MQTT:
    Level: DEBUG
    Foo: bar
OK, holidays are over, back to topic :slight_smile:
Logging:
    Syslog: yes
    Level: DEBUG
Connection1:
    User:
    Password:
    Host: 192.168.0.24
    Port: 1883
    Keepalive: 10
    TLS: no
    Level: DEBUG
SensorKingPin:
    Connections:
        MQTT:
    EventDetection: BOTH ( I tried Poll: 0.05 and Poll: 0.1 too )
    GpioChip: 0
    Pin: 18
    PUD: UP
    Level: DEBUG code here
I receive the same result, when starting with “OPEN”
When I start with a “CLOSED” PIN ( connected to GND ), I do not receive this error message.
But the result stays the same, only the initial message is published.
There is no need to treat the PIN as a button or to distinguish between short or longer openings ( maybe useful in the future ), At the moment, I would be happy if I could manage to publish the mqtt messages.
The short button press still occurs btw.
Jun 03 19:46:43 raspberrypi24 python[10123]: INFO - [RpiGpioSensor] KingPin Pin 18 changed from 0 to 1 (= OPEN)
Jun 03 19:46:43 raspberrypi24 python[10123]: INFO - [RpiGpioSensor] KingPin short button press occurred on Pin 18 was pressed for 5.003637 seconds
Jun 03 19:46:44 raspberrypi24 python[10123]: INFO - [RpiGpioSensor] KingPin Pin 18 changed from 1 to 0 (= CLOSED)
