I am getting ready to hook lfm-20 module to my garage opener.
I cut a computer power core but the colors are confusing me. One of the black wires is the line ( tested hot with my tester) but not sure about neutral and load. Should.I assume the other black is load and the blue is the neutral.
I’m not sure about the US (it looks like a us plug?), but in the UK and I think Europe, neutral and ground are connected together in or near the entrance to the property so you won’t be able to tell using a voltmeter…
An ohm-meter costs next to nothing - getting it wrong is likely to be a lot more costly
So the device is not in the database - can you provide a link to the device (that shows the configuration) and create an issue in the OH Issue tracker.
if that is not what you are looking for could you help me point to some resources to help me understand what you need?
there is no entry for this device in pepper1 database.
I also looked in the zwave server when I initially added this to the network but could not find anything. I might have been looking at the wrong place.
“Hello,
Unfortunately the LFM-20 does not have any specific configuration parameters. Here are the supported Command Classes for the device:
Z-Wave Supported Command Classes:
COMMAND_CLASS_SWITCH_BINARY
COMMAND_CLASS_SCENE_ACTIVATION
COMMAND_CLASS_SCENE_ACTUATOR_CONF
COMMAND_CLASS_SWITCH_ALL
COMMAND_CLASS_PROTECTION
COMMAND_CLASS_POWERLEVEL
COMMAND_CLASS_CONFIGURATION
COMMAND_CLASS_VERSION
COMMAND_CLASS_MANUFACTURER_SPECIFIC
• Z-Wave Controlled Command Classes: COMMAND_CLASS_SWITCH_MULTILEVEL
Please let us know if we can be of further assistance.
Regards,
Evolve Support”
everything still looks the same for me in my habmin. do i need to update anything?
edit 1: I replaced the zwave jar file with the new one from the cloudbees but not habmin is not even able to connect to openhab. the online status remains gray.
edit 2: tried to update the file again. this time habmin is able to connect but the product explorer list is empty and all the devices are missing from the devices tab as well
