- Platform information:
- Hardware: DS413j (Synology)
- OS: DSM 6.2.2
- Java Runtime Environment: Java SE embedded 8
- openHAB version: 2.4
- openwebnet addon version: 2.5.0.M3
- Issue of the topic: with PaperUI: when I try to add new OpenWebNet things a new scan starts and OpenHAB crashes
I just installed OpenHAB + OpenWebNet addon on my Synology NAS. Following instructions I managed to run the first two scans of my myHome system. The first scan correctly found my MH200N gateway. The second scan correctly found almost all my switches, CEN+ scenarios, and my thermostats.
With PaperUI I configured almost all automatically-found things and they’re working great.
Now I’d like to manually add some undiscovered things, like the blinds, but when I try to add an OpenWebNet thing a new system scan starts and immediately OpenHAB crashes. So I can’t reach the point where I could manually add/configure a new OpnWebNet thing. Is there a way to prevent a new scan and skip directly to “manually add thing”.
With Karaf I put the loglevel to DEBUG and that’s the log I get when a new scan starts (until death of OpenHAB)
16:51:39.762 [DEBUG] [very.OpenWebNetBridgeDiscoveryService] - ==OWN:BridgeDiscovery== getSupportedThingTypes()
16:51:39.779 [DEBUG] [very.OpenWebNetDeviceDiscoveryService] - ==OWN:DeviceDiscovery== getSupportedThingTypes()
16:51:39.966 [DEBUG] [very.OpenWebNetBridgeDiscoveryService] - ==OWN:BridgeDiscovery== getSupportedThingTypes()
16:51:39.976 [DEBUG] [very.OpenWebNetDeviceDiscoveryService] - ==OWN:DeviceDiscovery== getSupportedThingTypes()
16:51:40.525 [DEBUG] [very.OpenWebNetBridgeDiscoveryService] - ==OWN:BridgeDiscovery== getSupportedThingTypes()
16:51:40.535 [DEBUG] [very.OpenWebNetDeviceDiscoveryService] - ==OWN:DeviceDiscovery== getSupportedThingTypes()
16:51:40.568 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== --- Found device # urn:schemas-bticino-it:device:touchscreen:1
16:51:40.575 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - +=== UPnP =========================================
16:51:40.582 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.UDN : uuid:pnp-touchscreen-3_0-00:03:50:8F:28:24
16:51:40.593 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.DESC URL : http://192.168.1.50:49152/
16:51:40.609 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.MAX AGE : 500
16:51:40.618 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | --------------
16:51:40.626 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | MANUFACTURER : BTicino S.p.A. (http://www.bticino.it)
16:51:40.632 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | MODEL : LN4890 | Touch Screen Color | 3.0 (http://www.bticino.it)
16:51:40.643 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | FRIENDLY NAME: CionfolTouch
16:51:40.651 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | SERIAL # : 00:03:50:8F:28:24
16:51:40.669 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | BASE URL : null
16:51:40.679 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | UPC : null
16:51:40.685 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - +==================================================
16:51:40.696 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== |- LN4890 (BTicino S.p.A.)
16:51:40.702 [WARN ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== this BTicino device is not a OpenWebNet gateway or is not supported (UDN=pnp-touchscreen-3_0-00:03:50:8F:28:24)
16:51:40.721 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== --- Found device # urn:schemas-upnp-org:device:Basic:1
16:51:40.731 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - +=== UPnP =========================================
16:51:40.740 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.UDN : uuid:73796E6F-6473-6D00-0000-00113214b21c
16:51:40.749 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.DESC URL : http://192.168.1.200:5000/ssdp/desc-DSM-eth0.xml
16:51:40.755 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.MAX AGE : 1900
16:51:40.761 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | --------------
16:51:40.774 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | MANUFACTURER : Synology (http://www.synology.com)
16:51:40.782 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | MODEL : DS413j | Synology NAS | DS413j 6.2-24922 (http://www.synology.com)
16:51:40.792 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - +==================================================
16:51:40.801 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== |- DS413j (Synology)
16:51:40.810 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== --- Found device # urn:schemas-bticino-it:device:lightingcontrolunit:1
16:51:40.828 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - +=== UPnP =========================================
16:51:40.836 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.UDN : uuid:pnp-scheduler-1_0-00:03:50:01:D4:B0
16:51:40.842 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.DESC URL : http://192.168.1.40:49152/
16:51:40.858 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.MAX AGE : 500
16:51:40.866 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | --------------
16:51:40.872 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | MANUFACTURER : BTicino S.p.A. (http://www.bticino.it)
16:51:40.887 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | MODEL : MH200N | Scheduler | 1.0 (http://www.bticino.it)
16:51:40.893 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | FRIENDLY NAME: via Bucarest
16:51:40.904 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | SERIAL # : 00:03:50:01:D4:B0
16:51:40.912 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | BASE URL : null
16:51:40.925 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | UPC : null
16:51:40.989 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - +==================================================
16:51:41.027 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== |- MH200N (BTicino S.p.A.)
16:51:41.033 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== 'MH202' is a supported gateway
16:51:41.087 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== Created a DiscoveryResult for gateway 'via Bucarest' (UDN=pnp-scheduler-1_0-00:03:50:01:D4:B0)
16:51:41.121 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== --- Found device # urn:schemas-upnp-org:device:MediaServer:1
16:51:41.152 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - +=== UPnP =========================================
16:51:41.181 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.UDN : uuid:3628eb49-dc31-4307-85b4-bb1c34e5d9a2
16:51:41.200 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.DESC URL : http://192.168.1.106:2869/upnphost/udhisapi.dll?content=uuid:3628eb49-dc31-4307-85b4-bb1c34e5d9a2
16:51:41.225 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.MAX AGE : 900
16:51:41.233 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | --------------
16:51:41.251 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | MANUFACTURER : Microsoft Corporation (http://www.microsoft.com)
16:51:41.270 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | MODEL : Windows Media Player Sharing | null | 12.0 (http://go.microsoft.com/fwlink/?LinkId=105926)
16:51:41.289 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - +==================================================
16:51:41.296 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== |- Windows Media Player Sharing (Microsoft Corporation)
16:51:41.302 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== --- Found device # urn:schemas-upnp-org:device:InternetGatewayDevice:2
16:51:41.329 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - +=== UPnP =========================================
16:51:41.348 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.UDN : uuid:321a2f41-b2a6-e811-bdaa-0cb6d244742a
16:51:41.363 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.DESC URL : http://192.168.1.1:60853/rootDesc0.xml
16:51:41.391 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.MAX AGE : 60
16:51:41.409 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | --------------
16:51:41.419 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | MANUFACTURER : D-Link (http://www.dlink.com)
16:51:41.429 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | MODEL : DVA-5592 | D-Link router | DVA-5592_A1_WI_20180823 (http://www.dlink.com)
16:51:41.438 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - +==================================================
16:51:41.446 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== |- DVA-5592 (D-Link)
16:51:41.452 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== --- Found device # urn:schemas-upnp-org:device:MediaServer:1
16:51:41.465 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - +=== UPnP =========================================
16:51:41.473 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.UDN : uuid:00113214-b21c-0011-1cb2-1cb214321100
16:51:41.483 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.DESC URL : http://192.168.1.200:50001/desc/device.xml
16:51:41.491 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | ID.MAX AGE : 1900
16:51:41.500 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | --------------
16:51:41.510 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | MANUFACTURER : Synology Inc (http://www.synology.com/)
16:51:41.522 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - | MODEL : DS413j | Synology DLNA/UPnP Media Server | null (http://www.synology.com/)
16:51:41.531 [DEBUG] [nal.discovery.BusGatewayUpnpDiscovery] - +==================================================
16:51:41.540 [INFO ] [nal.discovery.BusGatewayUpnpDiscovery] - ==OWN:UPnP== |- DS413j (Synology Inc)
16:51:41.557 [DEBUG] [very.OpenWebNetBridgeDiscoveryService] - ==OWN:BridgeDiscovery== getSupportedThingTypes()
16:51:41.591 [INFO ] [very.OpenWebNetBridgeDiscoveryService] - ==OWN:BridgeDiscovery== ------ startScan() - SEARCHING for bridges...
16:51:41.618 [DEBUG] [very.OpenWebNetBridgeDiscoveryService] - ==OWN:BridgeDiscovery:ZB== Gateway NULL, creating a new one ...
16:51:41.742 [DEBUG] [very.OpenWebNetBridgeDiscoveryService] - ==OWN:BridgeDiscovery:ZB== ... trying to connect gateway ...
Thanks for reading!
Andrea
