Platform information: Rasp Pi 4 with 4GB Openhabian latest Version
My openhab system was working for more then a half year without any problems and yesterday wlan istn´t working anylonger. Problems with pasing IP it says in the openhab welcome screen after reboot. No change with plugged ethernet cable.
Is there a solution known? Yes I could start with a freshsystem and use a autobackup of the openhab, but anybody knows how to save my node-red configuration with all the flows I made?
In the moment the only way is to use a monitor and keyboard.
Is there a solution for the wlan problem or perhaps a known reason?
Where are (which folder) the flows located (should be one json file)
Can you maybe share some logging from your raspberry pi?
It looks like a problem with a static IP in the raspberry pi, did you set any that you know of?
Good to hear that it is working now!
Probably a problem with handing out the static IP to the Raspberry Pi.
Do you know if its better to set static IP at router level or in Openhabian?
Personally I would say, set in in your router. then you have a central point for the administration of your IP addresses. If for some reason your network changes, you only have to change it in your router.
