I am currently working on the topic openHAB and have already installed it on a Raspi 3.
Intermediate goal is actually that I am sitting in the living room and by Amazon Echo, TV (IR) Mac (WOL) and Yamaha Reciever (binding) goes on and off.
Currently it has come to a halt at the WOL.
I have installed the WOL binding (WOL (Wake-on-LAN) binding binding-wol1 - 1.9.0) via addons / bindings.
Now I want to select something in Inbox> Wake-on-LAN (WoL) Binding> Select Thing, but there is … nothing.
I thought maybe only through the Network Binding Addon there something appears … doesn`t help.
Does anyone have experience with it and can give me a hint?
Strange thing… currently I´m not 100 percent sure if it works or not.
The Mac is connected to a Master/Slave Connector strip which switches when I use the WOL Button, but the TV gets no Input
Don’t really understand your comment. I understood your TV was IR controlled, WoL binding won’t affect that. Maybe need an IR Blaster or something?
No idea how this “Master/Slave Connector strip” is controlled by whatever you mean by WOL button?
sorry that was a little bit confusing.
I have an MacMini which is connected to the TV via HDMI.
The Mac is even connected to a Master/Slave Socket which shines green when the Mac wakes up.
In this case I send to WOL Package to the Mac, the Sleeping LED on the Mac stops flashing and the Master/Slave Socket shines green. But the TV (which is all the time on in this testing case) shows no input.
Maybe its a Mac Problem with WOL. I will go further on this.
Good Day
I am currently starting with openHAB and i am complete noob!
Have no exp with script or any programming, although im learning as i go.
I want to create a WOL button to switch on my 2nd pc from my RPi3 with openhab interface.
I read the instruction on oH site and they are greek to me. I undertand the networking part, but not how to write an .item file and where to place it.
If anyone can link me a step by step guide for these basic beginner stuff i’d be glad, as i start doing these ill learn the program and be able to do more on my own as i go.
