I am new to OpenHAB and tried to use the WOL addon. After installing it, I did not know how to proceed. Apparently one needs to manually change a config file, since it is a legacy addon. So are there any plans of “upgrading” this to a normal addon?
I assume that would allow configuration via Web UI then.
This is an open source project. There are not plans so much as someone volunteers to do the work to rebuild the binding as a 2.0 binding. Volunteers are always welcome.
I think someone did, but I don’t know if it will get in the official add-ons section though. I tried installing it with the following steps in the PaperUI:
Go to Add-ons and, section MISC and install Eclipese IoT Market
Refresh the page and go to Bindings where you now find 3 different bindings when you type Wake on LAN
Click install on the one with the highest version number
After this I’n stuck as it’s not showing up in the Configuration > Bindings section and I can’t create a Thing.
Then, add these new items in your sitemap and you are ready.
When you flick the switch to ON, it will transmit (broadcast) the WoL magic packet to the network with the MAC Address as the recipient.
For the IP: Use the broadcast address of your LAN (ends in .255 for Class C networks)
Thank you very much @Dim for the clear example. I was finally able to create the item in a correct way I think. I don’t really know what you mean by SiteMap but I am trying to add a simple ON/OFF button to HAPpanel. So I can easily start the NAS. Can you point me in the right direction on how I can address the Thing in the HABpanel? The Item can be selected but I don’t know what Command value should be given…
That is unfortunate. There is the IOT Marketplace or you can distribute it yourself. However, with a binding like this, I strongly suspect someone will implement a 2.x version binding for distribution with OH. I do not expect that it is going to be easy to sell a binding like this for long.
