I just wanted to share my success with getting milight, astro, and a rule to work. I’m not claiming I’m an expert or even if this is actually the right way to do this, but it is currently working.
1 - You need the binding.milight and the binding.astro file in your addons folder. DO NOT put the action.astro and action.milight file in the addons folder.
2 - Configure your .cfg
################################# Astro Binding #######################################
# The latitude
astro:latitude=37.284540
# The longitude
astro:longitude=-80.042137
# Refresh interval for azimuth and elevation calculation in seconds
# (optional, defaults to disabled)
astro:interval=180
################################### Milight Binding ###################################
# Host of the first Milight bridge to control
milight:MilightId1.host=10.0.0.194
# Port of the bridge to control (optional, defaults to 50000)
milight:MilightId1.port=8899
# Host of the second Milight bridge to control
#milight:<MilightId2>.host=
#milight:<MilightId2>.port=
3 - items
for the items i have included a color picker, white light button, Discomode, and a speed controller. You can delete what you don’t need, but i wanted to show how to do as much as possible. I’m using the RGBW lights so i don’t think this will work exactly with just RGB, but you should only have to change a few things probably.
/////MiLight
//Front Porch Lights
Switch porchLights {milight="MilightId1;7;whiteMode"}
Color Light_Party {milight="MilightId1;6;rgb"}
Switch White {milight="MilightId1;6;whiteMode"}
Dimmer DiscoMode {milight="MilightId1;6;discoMode"}
Dimmer DiscoSpeed {milight="MilightId1;6;discoSpeed"}
//Time - Astro
//// shows the sunrise
DateTime Sunrise_Time "Sunrise [%1$tl:%1$tM %1$tp]" {astro="planet=sun, type=rise, property=start"}
DateTime Sunset_Time "Sunset [%1$tl:%1$tM %1$tp]" {astro="planet=sun, type=set, property=end"}
Switch Sunrise_Event {astro="planet=sun, type=rise, property=start, offset=0"}
Switch Sunset_Event {astro="planet=sun, type=set, property=end, offset=0"}
4 - Sitemap
Frame label="Front Porch Lights"{
Switch item=porchLights label="Front Porch Lights"
Colorpicker item=Light_Party
Switch item=White mappings=[ON="White"]
Switch item=DiscoMode mappings=[INCREASE='Next Disco Mode']
Switch item=DiscoSpeed mappings=[DECREASE='Slower', INCREASE='Faster']
5 - Rules
rule "Example Rule at sunrise"
Item Sunrise_Event received update ON
sendCommand(porchLights, OFF)
rule "Example Rule at sundown"
Item Sunset_Event received update ON
sendCommand(porchLights, ON)
I hope this helps someone struggling like i was and i may need to refer back to it later to fix what I’ve managed to muck up
