- Platform information:
- Hardware: amd64 / 4 cores / 8G RAM
- OS: Manjaro
- Java Runtime Environment: Oracle 11.0.18
- openHAB version: 3.4.2
- Issue of the topic:
I have a button here that posts temporary actions via mqtt like “simple”, “double” and “long” for associated tap behavior on the device.
This is mapped as a Thing and a Channel properly in openhab and I can see this in the log:
10:04:49.664 [INFO ] [openhab.event.ChannelTriggeredEvent ] - mqtt:homeassistant_zigbee2mqtt_5F0x00124b00253bab2a:6b3d5af049:zigbee2mqtt_5F0x00124b00253bab2a:0x00124b00253bab2a_5Faction_5Fzigbee2mqtt#sensor triggered single
10:04:49.673 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Bouton_VMC__eWeLink_WB01_zigbee2mqtt_Bouton_VMC__eWeLink_WB01_action' received command single
10:04:49.676 [INFO ] [openhab.event.ChannelTriggeredEvent ] - mqtt:homeassistant_zigbee2mqtt_5F0x00124b00253bab2a:6b3d5af049:zigbee2mqtt_5F0x00124b00253bab2a:0x00124b00253bab2a_5Faction_5Fzigbee2mqtt#sensor triggered
10:04:49.679 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'Bouton_VMC__eWeLink_WB01_zigbee2mqtt_Bouton_VMC__eWeLink_WB01_action' predicted to become single
10:04:49.685 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'Bouton_VMC__eWeLink_WB01_zigbee2mqtt_Bouton_VMC__eWeLink_WB01_action' received command
10:04:49.687 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bouton_VMC__eWeLink_WB01_zigbee2mqtt_Bouton_VMC__eWeLink_WB01_action' changed from to single
10:04:49.688 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item 'Bouton_VMC__eWeLink_WB01_zigbee2mqtt_Bouton_VMC__eWeLink_WB01_action' predicted to become
10:04:49.691 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'Bouton_VMC__eWeLink_WB01_zigbee2mqtt_Bouton_VMC__eWeLink_WB01_action' changed from single to
So the “simple” action command is received, immediately replaced by an empty action command because the state is temporary.
I’m trying to write a rule in MainUI that turns ON a switch item when the “simple” command is received, and here is the generated code so far:
configuration: {}
triggers:
- id: "1"
configuration:
itemName: Bouton_VMC__eWeLink_WB01_zigbee2mqtt_Bouton_VMC__eWeLink_WB01_action
command: simple
type: core.ItemCommandTrigger
conditions: []
actions:
- inputs: {}
configuration:
itemName: VMC_5_Minutes
command: ON
type: core.ItemCommandAction
Unfortunately, I’m not seeing the rule being triggered in the log, and the switch item is not turned on.
I have also tried with the following trigger:
- id: "1"
configuration:
state: simple
But it does not send the “ON” command either.
What have I missed here?
