I am new to this community and this is my first question. I managed to configure a couple of Xiaomi/Aqara temeprature and humidity sensors and a Sonoff 4CH so that I can see them in Control page of Paper UI. I can also successfully set the status of Sonoff outputs by sending MQTT commands. Now I would like to write a simple rule to drive the outputs of Sonoff based on temperature readings.
I am stuck in the beginning, since there is something wrong in my simple rule. The rule should be self explaining. What happens is that the “if” statement always evaluates to true, even when “tempAqara1” is higher than “threshold”.
It looks like your Aqara1_Temperature item includes a unit of measurement. Have a look at this very recently revived thread on using IF with those types of items:
In short, I think you want to do something like:
if ( Aqara1_Temperature.state < 28.5 | "°C" )
or
if ((Aqara1_Temperature.state as Number).floatValue < 28.5 )
(I would recommend getting your rule to work with base components, before moving to using var and val…)
var threshold = 28.5
//Or 28,5
rule "ch1_sensor1"
Item Aqara1_Temperature received update
if (Aqara1_Temperature.state < threshold)
logInfo("Aqara Temp-Humidity Sensor #1", "Temperature update received: " + Aqara1_Temperature.state.toString + " < " + threshold.toString + "°C")
else
logInfo("Aqara Temp-Humidity Sensor #1", "Temperature update received: " + Aqara1_Temperature.state.toString + " > " + threshold.toString + "°C")
This is how I do number comparison
For example:
rule "Ist es draußen wärmer?"
Item AlexaGereate_IstEsDraussenWaermer received command
logInfo("Rule started", "\"AlexaGeraete_Diverses.rules: Ist es draußen wärmer?\"")
var DeltaT = Math::abs((Heizung_DeltaT.state as Number).floatValue) //Zahl zum String machen
var DeltaT_String = DeltaT.toString().substring(0,3).replace('.',',') //String zuschneiden und formatieren
var Innentemperatur = Heizung_AktuelleTemperatur.state.toString.substring(0,4).replace('.',',')
if ( DeltaT < 0.3 ) //Gleich warm
AmazonEcho_Maze_TextToSpeech.sendCommand("Es hat drinnen " + Innentemperatur + " Grad und ist damit gleich warm wie drauĂźen")
else if ( Heizung_DeltaT.state > 0 ) //Drinnen kälter
AmazonEcho_Maze_TextToSpeech.sendCommand("Es ist draußen um " + DeltaT_String + " Grad wärmer als die Innentemperatur, welche " + Innentemperatur + " Grad beträgt")
else //Drinnen wärmer
AmazonEcho_Maze_TextToSpeech.sendCommand("Es hat drinnen " + Innentemperatur + " Grad und ist damit um " + DeltaT_String + " Grad wärmer als draußen")
Any reason not to attach your MQTT channels to Items, and then control those Items (ON/OFF) instead?
It would mean you could get rid of a bit of your code, down to something like:
var threshold = 28.0 as Number
rule "ch1_sensor1"
var tempAqara1 = Aqara1_Temperature.state as Number
if (tempAqara1.floatValue < threshold)
logInfo("Aqara Temp-Humidity Sensor #1", "Temperature update received: " + tempAqara1.toString + " < " + threshold.toString + "°C")
sendCommand("sRelay1", "ON")
else
logInfo("Aqara Temp-Humidity Sensor #1", "Temperature update received: " + tempAqara1.toString + " > " + threshold.toString + "°C")
sendCommand("sRelay1", "OFF")
This assumes attaching the appropriate channels to an Item called sRelay1. Not too long ago I (tried to) help someone else setup their 4 channel Sonoff:
Thank you for all suggestions. “.floatValue” was the key to success. I will anyway read each pieace of your rules, since I can find tips for improving mine.
@Felix_Schneider I assigned solution to @hafniumzinc, since it was first successfull suggestion. @hafniumzinc: I accept your suggestion to define an Item to clean up the code. I will work on it.
