Wrong popup notification in Android openHAB Beta
I have Openhab installed sending pushmessages using
sendNotification("user1","This is a test")
In myopenhab these messages only show up for user1.
In the Android-app openHAB Beta I get the following behavior:
  • user1 sees the notification in “notifications” (expected behavior) and receives pop-up (expected behavior)
  • user2 does not see the notification in “notifications” (expected behavior) but receives pop-ups (not expected behavior)
I assumed, that user2 should not get pop-ups. I can use workarounds with pushover/… but I would like to understand the app in order to reach high WAF.
Thanks for any hint!
Best regards
Peter
after several tests, I assume (!) this is a problem with myopenHAB, but I still wonder why I seem to be alone with this problem.
Searching the forum I found this topic
myopenHAB Mobile Notifications Temporarily Disabled - #20 by zamzon)
and I remember that my account was affected by this problem.
@digitaldan… is it possible, this is some kind of “leftover” from above problem?
Thank you
Best regards
Peter
