Wrong switch state in Basic UI
I’ve noticed that there seems to be an issue with “invisible switches” in Basic UI.
This is the switch definition in the item file:
Switch gl_vsw_tresorpin "Schlüsseltresor PIN sichtbar" { expire="10s,command=OFF" }
And this is the sitemap:
Switch item=gl_vsw_tresorpin label="Schlüsseltresor-PIN anzeigen" icon="keyring" visibility=[gl_vsw_tresorpin!=ON]
Turning on the switch will make the switch disappear because of the visibility-setting - that’s fine. After the 10s timer of the Expire-Binding has expired, the switch will turn off and be visible again. That’s fine too - but the switch is shown as ON, not OFF then! I’ve to reload the browser page (Ctrl+F5) to have the switch shown as OFF.
There is no such issue with the openHAB Android App.
I think it’s a bug - do I have to report it at GitHub · Where software is built?
I’ve filed an issue: Wrong switch state shown in Basic UI · Issue #3909 · eclipse-archived/smarthome · GitHub
