I recently migrated from OH1 to OH2.
But one rule does not work as expected.
It looks like the rule is getting wrong data.
I try to compare a current temperature to the value from two minutes ago.
logInfo("Showering", (Temp_Bath.state as DecimalType) + " " + (Temp_Bath.historicState(now.minusMinutes(2)).state as DecimalType))
As you can see in the logs, the older value is constantly lower than it should be.
2017-05-21 18:17:58.625 [INFO ] [pse.smarthome.model.script.Showering] - 25.7500 23.291666666666667850904559600166976451873779296875
2017-05-21 18:18:29.125 [INFO ] [pse.smarthome.model.script.Showering] - 25.8125 23.333333333333332149095440399833023548126220703125
2017-05-21 18:18:59.518 [INFO ] [pse.smarthome.model.script.Showering] - 25.8125 23.333333333333332149095440399833023548126220703125
2017-05-21 18:19:30.015 [INFO ] [pse.smarthome.model.script.Showering] - 25.8125 23.291666666666667850904559600166976451873779296875
2017-05-21 18:20:01.347 [INFO ] [pse.smarthome.model.script.Showering] - 25.7500 23.291666666666667850904559600166976451873779296875
2017-05-21 18:20:31.251 [INFO ] [pse.smarthome.model.script.Showering] - 25.8125 23.291666666666667850904559600166976451873779296875
2017-05-21 18:21:01.709 [INFO ] [pse.smarthome.model.script.Showering] - 25.8125 23.291666666666667850904559600166976451873779296875
2017-05-21 18:21:32.334 [INFO ] [pse.smarthome.model.script.Showering] - 25.8125 23.291666666666667850904559600166976451873779296875
2017-05-21 18:22:02.716 [INFO ] [pse.smarthome.model.script.Showering] - 25.8125 23.292708333333333570180911920033395290374755859375
2017-05-21 18:22:33.302 [INFO ] [pse.smarthome.model.script.Showering] - 25.8125 23.292708333333333570180911920033395290374755859375
Even the chart seems to be showing wrong values.
http://openhab:8080/chart?items=Temp_Bath&period=W
I am using rrd4j in case that is important.
But I hab no problems with this rule with openhab1.
I copied the rrd files from openhab1 to OH2 to preserve my data.
To make sure this is not the problem I let OH2 recreate the Temp_Bath.rdd from blank.
But the issue still exists.
Any idea what the problem is?
